NO CA FOUND/FILE TO BIG FIX
  • checkersceltic
    • Jan 2012
    #151
    file to big solution???
    hi there i seem to have the same problem as yourself, i have seen your thumbnails but i cant figure out what you did to resolve it. can you please explain what you did to a bnovice like me!!! thanks in advance
    • mongje
      • Jan 2012
      also file to big issue
      how can i know if i use the right null modem cable?
      • khristos
        • Feb 2012
        #153
        Originally posted by halau
        If you have bought an 800 recently and come against some problems with flashing then this might be the fix for you
        I was told my box was 75 bootloader but ok for 72 aswell i tried to flash and got the ' NO CA FOUND '
        Some times it would boot up with dreamup in 'serial http mode' but could never find a working IP and failed when trying to flash,
        The rest of time it would boot up in dreamup with the 'NO CA FOUND SeCOND STAGE BOOTLOADER' this would allow me to use enforcer but came up against the 'FILE TOO BIG' problem
        If you have problems like these try my method below it worked for me
        any help?
        /10chars
        • Jossies
          • Jul 2010
          • 12
          #154
          I have a similair problem.
          When starting dreamup and turning on my dm800 clone, nothing happens. Not even the boxes name comes up.
          Dm's display says: error01 no ca found and it stays that way.
          nullcable is good, used it on a different db.
          when using a different debug version it give a hardware break error.
          thats all i get.
          Can someone explain me if there is anything i can do?
          Thx
          • mcwago
            • Nov 2010
            my expirience
            DM800HD bl59, no clone -> NO CA FOUND
            first repaired over NCF CA repair.
            i've uploaded secondstage-dm800-69.nfi from
            Index of /diverses/secondstageloader/dm800 over Optiflasher and now the dm awaiting dhcp
            • khristos
              • Feb 2012
              #156
              NO CA found/ File too big
              Okay I download all the files you guys suggested, also did from several other forums too.
              I have the patched dreamup both versions.
              I use a com connection and an ethernet to router/ethernet to PC. None of them works
              When I start the dreap up, it connects, when I try to flash I always get teh file to big error. I trid several firmwares but no luck still the same message and I dont know what else to do.
              DM 800 HD PVR
              Version sim 2.0.1
              No idea if its clone or not.
              Any help what goes wrong here? The file too big is always there and QUITE annoying.
              Please help somehow.
              • jorgesipp
                • Feb 2012
                NO CA found enforcer
                hi,
                can anyone tell me where to download the enforcer please?
                thanks a lot
                • stinguss
                  • Feb 2012
                  thanks but the problem is always there I can't reflash my clone DM800
                  • timigo
                    • Jun 2011
                    The same problem, "No CA found by 2nd stage loader + big file", I can't send the image by dreamup and the network is locked, any ideas? Thanks.
                    • ram3322
                      • Mar 2012
                      I have the same probleme
                      Error1 No CA FOUND
                      DREAMBOX DM800 HD PVR
                      Help
                      • DBTraitor
                        • Feb 2011
                        • 616
                        #161
                        fix(read here)
                        DreamOEM - NCF SIM2 V2.1 Updates
                        A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                        • asus9
                          • May 2012
                          For those who have problem with the NO CA FOUND problem dont give up on trying. Last few days I was having that problem,I bought a few cables but it doesnt solve the problem
                          I have tried usb to usb cable, rs232 to usb, rs232 to rs 232 but not to availability. Other than that, I have tried the dreamup, ncf, optiloader software but still cannot detect my dm800hd and I personally recommend to you all to make your own null model cable and find an old pc/laptop that has rs232 port.
                          The things required to make a null modem cable is by using this diagram (http://digital.natinst.com/public.nsf/$CXIV/ATTACH-AEEE-82HQFA/$FILE/Strait%20Through.jpg). I just need 2 x rs232 connector, wires, solder to make the null cable.
                          After using the null modem cable, I used ncf software to fix the problem and within a minute the problem is solved
                          • Manator
                            • Oct 2011
                            #163
                            still dead
                            please any sollution? i have no ca../file to big and im not able to use com or network seems to be locked .. any help please?
                            used all the metods arround and still no luck
                            i have a dm800hd pvr sim210
                            please help
                            M
                            • Manator
                              • Oct 2011
                              #164
                              help
                              hello mate
                              i have the same problem i cant connect by null cable or network and big file problem ..do you ever fixed the problem?
                              i have test everything with diferents programs and no luck ..any help would be priciate
                              BR
                              M
                              • atifpervaiz28
                                • Jun 2012
                                look at www.dm7020.com no ca found error how to fix
