All DM900CII user that did a Master Reset and unable to view channels, Come In
This topic is closed.
1st, are you using DM900CII?
I only know this model, the rest I don know.
Do a master reset again, then TP scan.
then
Press YELLOW to go to MENU again
Press BLUE repeatly till COMMAND Box comes out
Command: f8 ffffffffffffffffffffff all the way.
this should work alreadyComment
Model is Correct
Did exactly what you mentioned, still it did not work...my demand channels are gone after master reset, would greatly appreciate if you can suggest other alternative.
Thanks!!
CableGuy888Comment
DM900CII
I did not do any reset can i cant view any of the digital tv channels at all. shud i reset? anyone can help?
I followed your instructions from the system master reset and all I got was only channel one (a European channel) the rest did not work. Do you think I can still do an update like one of the members' recommended?
box not working for the past few days. We managed to program the world cup recently but system suddenly stopped working some 3 days ago.
I upgrade my 900CII with 5th Gen Card inserted <--> DM900C-V, rubbish box turn into usable box.
I'm not sure if upgrade with 2nd Gen Card or old card, will solve problem or not
Reply from China side:
those DM900CII user this few days, unable to view channel, due to unknown reason, even if we have key in the correct code, but unable to watch, means that need to change to new card --> 5th Gen Aucard.
I perform system udate my 900CII - DM900C-V via serial cable, with 5th Gen aucard plugged in, problem solved.
Therefore, to solve the problem, new card is needed.Last edited by nipulu77; 2 August, 2010, 09:19.Comment
Take Note !!!
The 5th generation card does not support auto key roll in DM900Cxx. If provider change the key, you need to manually input the correct key again in order to watch. But the card work petty well on auto key roll in others box like 801/5288/5688/2011, mk3388, fy901c, ...
To test on your dm900c, try changing the key 00/01 to any any incorrect key. You will face cannot watch paid channel. Even for a couple of minutes still cannot autoroll. This prove that it doesn't support auto roll key.Comment
