please help me with my wii
  • Specialkey
    • 38
    I installed the homebrew channel using letterbomb then I installed neogamma but my backup does not work I get this message: dvd- + no cios.
    Can someone help me guys?thanks.
    I should have used modmii like always but this time I am stuck.
    Please help.
    Thanks.
  • wernley
    • 113
    Wiihacks softmod any wii will save it pal google your friend and I used the guide and as it says any wii whatever ;-)
    • Specialkey
      • 38
      After the homebrew channel do I need to install Cios?
      • Keithuk
        • 2264
        Obviously LetterBomb is for a 4.3 Wii but what was your Wii version before and how old is your Wii because NeoGamma can only be used to play burnt and original discs?
        Nintendo fitted different DVD players in the latter Wii's to stop people playing burnt discs. Add sysCheck v2.1.0 Beta 11 to your SD card and run it from HBC and check if it says The drive supports DVDs near the top. You could post the sysCheck report saying which IOS's you are using.
        Keith
        2010 Golf GTD (170)
        • wernley
          • 113
          Or use the guide I posted put all cios on wii and if it is a wii that can't play back up discs wii is softmodded to use hard drive or USB stick easy ;-)
          • Specialkey
            • 38
            My wii was 4.3 e I only used letterbomb to install homebrew channels and nothing else,I think that is the problem.
            Can I run modmii even if I have installed homebrewchannel with letterbomb already?
            Thanks a lot.
            • Specialkey
              • 38
              syschecher
              this is my syschecker report:
              ...runs on IOS58 (rev 6175).
              Region: PAL
              System Menu 4.3E (v514)
              Homebrew Channel 1.0.8 running on IOS58
              Hollywood v0x11
              Console ID: ---------55
              Boot2 v4
              Found 54 titles.
              Found 38 IOS on this console. 14 of them are stub.
              IOS4 (rev 65280): Stub
              IOS9 (rev 1034): No Patches
              IOS10 (rev 768): Stub
              IOS11 (rev 256): Stub
              IOS12 (rev 525): No Patches
              IOS13 (rev 1031): No Patches
              IOS14 (rev 1031): No Patches
              IOS15 (rev 1031): No Patches
              IOS16 (rev 512): Stub
              IOS17 (rev 1031): No Patches
              IOS20 (rev 256): Stub
              IOS21 (rev 1038): No Patches
              IOS22 (rev 1293): No Patches
              IOS28 (rev 1806): No Patches
              IOS30 (rev 2816): Stub
              IOS31 (rev 3607): No Patches
              IOS33 (rev 3607): No Patches
              IOS34 (rev 3607): No Patches
              IOS35 (rev 3607): No Patches
              IOS36 (rev 3607): No Patches
              IOS37 (rev 5662): No Patches
              IOS38 (rev 4123): No Patches
              IOS50 (rev 5120): Stub
              IOS51 (rev 4864): Stub
              IOS53 (rev 5662): No Patches
              IOS55 (rev 5662): No Patches
              IOS56 (rev 5661): No Patches
              IOS57 (rev 5918): No Patches
              IOS58 (rev 6175): USB 2.0
              IOS60 (rev 6400): Stub
              IOS61 (rev 5661): No Patches
              IOS70 (rev 6912): Stub
              IOS80 (rev 6943): No Patches
              IOS222 (rev 65280): Stub
              IOS223 (rev 65280): Stub
              IOS249 (rev 65280): Stub
              IOS250 (rev 65280): Stub
              IOS254 (rev 65281): BootMii
              BC v6
              MIOS v10
              Thanks a lot
              • Specialkey
                • 38
                Anyone can help?
                • happy_highlander
                  • 3535
                  Anyone can help?
                  Yes I can help you are the second person in a week that has managed to stub out your cios 249 which is the cios that neogamma and most other loaders use to run. Take that syscheck csv that you have just posted and download modmii from the dk downloads section. Load modmii into the pc and run it. Let it update and follow the instructions, when you get to the main menu select the update softmod section (or similar to that) and put the csv file iyo it when requested, this will then download all your missing cios and update all the ios. You then just load them into the wii with your wad manager
                  • Keithuk
                    • 2264
                    Ok its always been 4.3 which means there is no point in having NeoGamma as you can't play burnt discs.
                    As mensioned you don't have IOS249 so you may as well install Digital Kaos - Downloads - D2X v7 WAD PACK then you will have IOS245 to IOS251 and register them all with MMM which is all you need to use an external USB drive with any of the USB Loaders.
                    Keith
                    2010 Golf GTD (170)
                    • happy_highlander
                      • 3535
                      Neogamma r 9 has usb hdd support keith but as with the discs it will only load them with cios 249 as far as I know it doesn't have the option to change cios
                      • Keithuk
                        • 2264
                        I tried NeoGamma R8 and burnt a game disc with ImgBurn but it just brings up a DVD read 1167 error, obviously the later DVD drive, I haven't bothered trying R9. Its not really worth buying good quality DVD's when you have an HDD.
                        Keith
                        2010 Golf GTD (170)
                        • happy_highlander
                          • 3535
                          You are right keith. I can use disc but don't see the point of using them due to cost and the fact the wii can only read them at 3x speed when it reads an original at 6x resulting in occasional game lag or loading problems
                          • victorbuc
                            • Apr 2012
                            Thanks a lot that helped me too
                            • lovechief2003
                              • Apr 2012
                              i have the same problem too.
