have a similar problem and appreciate all the help on here!
usb loader cant find HD
ok, I have the problem with GX Loader not having the right IOS. I couldn't get the wad working, Homebrew ran ok but no icons came up, shall try again now and shall browse this (great) forum some more..
ref the WAD, do I just copy that to a blank sd card, insert into wii, run Homebrew?
if any kind hearted souls get the chance to review my sys report, it is below.. sorry to ask so soon but I am tired after dismantling laptop for 3 hours after inserting sd card into optical drive.
Thanks, Pete
sysCheck v2.1.0b18 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Drive date: 2008.07.14
Homebrew Channel 1.1.0 running on IOS58
Hollywood v0x11
Console ID: 84881143
Boot2 v4
Found 74 titles.
Found 47 IOS on this console. 17 of them are stub.
IOS3 (rev 65280): Stub
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS62 (rev 6430): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2012/11/28.
sysCheck #ngUIaOsy
Welcome to DK.
Yes you have 17 stubs in that report that need to be fixed. Now most of these IOS's are available in the download section. I would say your best way now you have a sysCheck.csv file from that sysCheck is download ModMii and run that from Windows. From the main menu type in SU (SysCheck Update) and download all the update wads needed from the COPY_TO_SD sub folder and add them to your SD card. Run Homebrew and install IOS236-v5-Mod first then install the other wads with MMM.
Now ModMii doesn't add all the d2x v8.0 wads so download them d2x v8 final wad pack and add them to the wad folder on the SD card.
Homebrew ran ok but no icons came up thats because there are no Wii apps in the apps folder on the SD card.
If you don't like messing about with the SD card in your laptop, get yourself an USB SD card adaptor.
After your installed all the wads run sysCheck and posty a new report.Keith
2010 Golf GTD (170)Comment
great, that's much appreciated, I shall follow your steps tomorrow. Is there a wad app that I ought to be using? thx
I tried wad mgr tonight but it hangs..Comment
The main ones that are missing are Full cIOS Wad Pack d2x v8 is added to these. As I said you need to install IOS236-v5-Mod from ModMii first then install the rest.
When its done you should have wads that look like these.
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
That should take care of 12 of the stubs.Keith
hmm, when I try to install IOS236 v5 using MMM I get an error "1 did not complete" - I have been digging around to resolve but no joy so farComment
ok, struggling a bit here. cannot install any wads (just tried another batch of 11 and none completed) have tried MMM and WAD Mgr 1.7
are there any clues in the sys file as to what the problem might be (aside from end-user competence)?
trying direct from sd - into mmm - then Wad Manager option
thanksComment
You haven't read and understood what I've said.
You must run ModMii with the SU option and your sysCheck.csv. That will make a IOS236-v5-Mod folder in the apps folder which you run from Homebrew first.
After you have installed IOS36 in IOS236 with IOS236-v5-Mod from Homebrew not MMM you can come back out and run another sysCheck it will now show
Then you use MMM to install all the other wads in the wad folder.
The WAD Manger 1.5 & 1.7 never work for me, MMM works everytime. Wait for the message Installed OK after each wad is installed.Keith
ok, latest sys report attached
haven't been able to test yet as I am now struggling with USB format
Region: PAL
Priiloader installed
Hollywood v0x11
Boot2 v4
Found 84 titles.
Found 55 IOS on this console. 5 of them are stub.
IOS11 (rev 16174): Trucha Bug NAND Access
IOS20 (rev 16174): Trucha Bug NAND Access
IOS30 (rev 16174): Trucha Bug NAND Access
IOS40 (rev 16174): Trucha Bug NAND Access
IOS50 (rev 16174): Trucha Bug NAND Access
IOS52 (rev 16174): Trucha Bug NAND Access
IOS60 (rev 16174): Trucha Bug NAND Access
IOS70 (rev 16174): Trucha Bug NAND Access
IOS80 (rev 16174): Trucha Bug NAND Access
IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
BC v6
MIOS v10
sysCheck #zUjoBZ3GComment
well, if I had been sitting on a tree at the time, I would have fallen out of it... this now works!
I just need to work how to set the sd card as the cfg loader default and maybe try to fix usb drive issue - although happy to stay with sd card
thanks Keith, kind of you to go out of your way to helpComment
That sysCheck look ok you have the correct wads installed.
I see you have Priiloader installed thats something I forgot to mention with sorting out which wads you needed to install. I assume you have blocked online and disc updates? I get rid of the annoying safety 'A' prompt on startup as well.
Have you install any Forwarders so you have the USB Loaders on the Wii menu rather than running Homebrew just to run a USB Loader?
USB Loader GX Forwarder put USB Loader GX-UNEO_Forwarder_5_1_AHBPROT.wad in the wad folder on the SD card and install it with MMM. Just scroll down all the wads and press the + button on that wad name, that will put a green tick next to it. Press 'A' then 'A' on the next screen to install wait for the Installed OK message.
Now you talking about CFG USB Loader? You don't have to set anything up to use any USB Loader providing the USB drive is formatted correctly and the games have been added correctly.
Personally I always use USB Loader GX because there are more cracks for games and its easy to change the game wads for specific games.
Your next job is to find a compatible mains powered external USB drive to add your games onto. If you need to know how to add games to a drive this has been talked about many times on here if you search, or ask.
USB Compatibility List
http://wiki.gbatemp.net/wiki/USB_Devices_Compatibility_ListKeith
yeah thankfully the reformat of the USB drive worked and all is ok now on both SD and USB.
the Priiloader has blocked online and disc updates, thanks for the tip about the safety prompt, I shall try that.
the cfg loader is on the start menu and the Homebrew channel - did try GX originally but obviously it didn't work with stubbed wads.
I found the ModMii wizard to be fantastic - worked a treat - even with having Homebrew already set up. I took a bit of a risk and just installed all of the wads that came with it and it was fine, before installing d2x v8. As you may have guessed earlier I was delayed by trying to install IOS236-v5-Mod via MMM and not ModMii (wasn't ignoring your instruction, just a mistake by being on autopilot)
next plan is to set up the homebrew browser
thanks again, PeteComment
I have homebrew browser but I don't use it that much, you can download a few apps. Just add it to the apps folder on the SD card.
You can add a few games to the SD card as well, Mahjongg Wii and Rokoban (Sokoban) are quite good.Keith
