Remove crack from WII
  • Beccy
    • Feb 2012
    • 54
    About 3 years ago my ex put some sort of crack on my WII so he could play downloaded games. He told me never to update of connect to internet as it would brick it
    The wii has since been boxed up for 2 years until I decided to set it back up. However I want to remove this crack thingy as I want to be able to update etc.
    The wii has version 4.0e it also has an SD card in it which the ex told me not to remove.
    Can someone please explain to me how to remove and get my wii to how it should be.
    Also I must mention that I am not very technical so please go easy on me
    All help will be much appreciated
  • Keithuk
    • 2264
    Welcome to the forum Beccy.
    Well unless we know what crack he used then its going to be difficult to say how to remove it.
    Do you have the Homebrew channel on the Wii menu?
    If it is Homebrew there is an option to uninstall Homebrew and Bootmii but you would have to softmod it again to see this. I don't know if uninstalling both is successful.
    What do you want to update your Wii to 4.3?
    If you want to update it to 4.3 that would be fine as that will remove the softmod then you would have to softmod it again using LetterBomb then you would have to setup your USB Loaders again.
    Those are my thoughts if someone else knows any better then we will have to wait and see.
    Keith
    2010 Golf GTD (170)
    • Beccy
      • Feb 2012
      • 54
      Yes homebrew
      Yes I have the homebrew channel.
      I just want my wii back to normal so I can play paid for games as I do not download games so not sure if I would need to softmod it.
      I have just bought just dance 3 and it won't play which I am assuming because it needs the update.
      What do you think?
      • happy_highlander
        • 3535
        You missed a very important question before recommending, updating....beccy can you play backup game discs on the normal disc channel(ones that have been burnt tho a blank dvd). If you can, do not update to 4.3 as darkcorp has been installed and you will brick the wii. Why won't just dance 3 play and is it original......is it because you don't want to accept the update, if so then there is a thread on here for a safe update to 4.2 which will not brick the wii or lose the softmod. First thing to try is to see if priiloader has been installed to do this turn the wii off until the red light is on then press and hold the reset button and press the power button to switch the wii on still holding reset. If it starts as normal priiloader has not been installed. Try these first then get back to us with the answers
        • Beccy
          • Feb 2012
          • 54
          Yes I can play backup games discs.
          No idea why just dance won't work. It's not even suggesting update. It loads into disc channel, I press A then screen goes black.
          I did the reset and start thingy and it came up with a black screen saying in top middle "system menu homebrew Channel installed file"
          Bottom left "IOS V60, system menu v418"
          Bottom right "preloader v0.29"
          • happy_highlander
            • 3535
            I know you can play backup game discs but can you play them from the disc channel in top left. If so you have darkcorp installed which had altered almost all system files and will be the reason why just dance won't play, the game is pretty new and the version of darkcorp will be pretty old. It is very important we know if darkcorp is installed.
            • Beccy
              • Feb 2012
              • 54
              Yes I can play them from the disc channel. Apologies I did mean to say that
              • happy_highlander
                • 3535
                ok then do not update via nintendo or you will brick the wii...best option you have is to do a complete softmod...It is pretty easy and we will be about to answer any questions...You will need to download and install this onto your pc Digital Kaos - Downloads - modmii 4.3.4 you run this on the pc and allow it to update to the latest version you will then need to follow the first instruction...After you have done that and have the main menu select "w" for full softmod wizard...then follow the instructions....You will need and sd card which you have already in the wii, take that out and format it to fat or fat32
                You are going to get a few options in this program and the only one i would do different from what the program recommends is instead of selecting the recommended system version of 4.1 choose 4.3 as this is the latest system menu so discs should not update yo further
                • happy_highlander
                  • 3535
                  If you don't want to do a softmod I can walk you through removing darkcorp. Just dance will then work and will perform a system update which will remove the softmod but I can't guarantee it won't brick the wii (it is unlikely after darkcorp has been removed but may still happen)
                  • Beccy
                    • Feb 2012
                    • 54
                    Unfortunately I don't have an SD card reader on my PC as my ex did it all on his. I am however seeing if I can loan one from someone.
                    If I go with the second option of uninstalling what is the likelihood I it bricking.
                    • Beccy
                      • Feb 2012
                      • 54
                      Result! Daughter has card reader on her laptop.
                      Gone give it a shot.
                      Thanks for all your help, you are truely amazing.
                      Will be back if I get stuck
                      • happy_highlander
                        • 3535
                        Unfortunately I don't have an ad card reader on my PC as my ex did it all on his. I am however seeing if I can loan one from someone.
                        The second options still requires files to be written to the sd card from the pc...It is the same risk as updating any softmodded wii with an official update. Low but still very possible. Every system change is done via the sd card so until you can sort out a reader you are kind of stuck with what you have. In the meantime I would suggest you have a bit of a play with modmii and see what it is suggesting you do. You can then have most of your questions answered before you even start to redo the softmod (which is my recommendation of the two options I have given you) purely because it is safer for a newbie...Darkcorp is a pig to get rid of properly
                        • happy_highlander
                          • 3535
                          good luck and take your time...Reading is the key to success
                          • Beccy
                            • Feb 2012
                            • 54
                            I have downloaded, let it run and it updated to 6.0.2 is this correct?
                            • happy_highlander
                              • 3535
                              yes that's correct
                              Edit remember you do not have to install bannerbomb again as you already have hbc (homebrew channel) you want to start the process from stage 2 you will need a 2gb sd card make a nand backup..It is important......You can then transfer the nandbackup to the pc and use the sd card for the rest of the softmod, you do not have to remove the health screen and move the disc channel in prii loader system hacks stage 5 but disc and online updates do need to initialised
                              Last edited by happy_highlander; 15 February, 2012, 00:02. Reason: importance of nand backup
