Remove crack from WII
  • Beccy
    • Feb 2012
    • 54
    #106
    doent matter i have done it. silly me had to just press reset
    • happy_highlander
      • 3535
      #107
      Originally posted by Beccy
      it says to press A to (reset) continue but the remote doesnt work so what do i press to make it continue?
      it doesn't it says press a (reset) to continue meaning the reset button is your a button
      • happy_highlander
        • 3535
        #108
        After you have got your new nand backup save it to your pc remember what files you need from the last time naming the folder accordingly...You can delete the one with darkcorp still on it now from the pc..I would advise keeping at least 2 copies of your working nand backup in different places I have 3, 2 on different hard drives and 1 on an sd card with lock tab down so it can't be overwritten. Because you have bootmii as boot2 and a working nand backup you will be able to recover from any brick no matter how severe. We will now prepare your sd card to add another dis launcher for the backup discs yo have. Let me know when your ready
        • Beccy
          • Feb 2012
          • 54
          #109
          all that is done and even backups sorted. am ready for next step
          • happy_highlander
            • 3535
            #110
            Ok make sure you have all the nand files you need because you are about to format the sd card unless you have a spare one that is only needs to be a bout 16mb. choice is your either format that sd card or format a spare one to either fat or fat 32...I'll start writing the next step for when your ready.
            • Beccy
              • Feb 2012
              • 54
              #111
              I have backed up everything that was on the SD card as I do not have a spare.
              SD card now formatted to FAT 32
              • happy_highlander
                • 3535
                #112
                Download this file Digital Kaos - Downloads - Neogamma R9beta56 with forwarder and mmm and extract it to a blank sd card. put the card in the wii and start hbc then launch mmm and navigate down to reload another ios and select 249 then go to wad manager and and press "a" to select and install the only wad in the folder. Go back to wii's main menu and you will have another channel called neogamma this is for launching your backup discs or your originals if they are trying to do a system update. You must leave this sd card in the wii for negamma to work. And you will never need the files from the old sd unless you want to launch bootmii for recovery or change settings in priiloader. I know you have just formatted the sd with all the files but remember they are the same files that you downloaded from modmii so you already have a copy of them on the pc. If you need them just copy them over again
                • Beccy
                  • Feb 2012
                  • 54
                  #113
                  all done
                  • happy_highlander
                    • 3535
                    #114
                    all done
                    Congratulations now try just dance and make sure it works then try a backup in neogamma and happy gaming....Let me know if they work ok and you know where we are if you have any further problems or decide you want to install an external hard drive to run backup games from.
                    • Beccy
                      • Feb 2012
                      • 54
                      #115
                      You are f**king amazing and i could just kiss ya
                      everyting is working just fine and dandy.
                      I really cant thanks you enough for you time and your patience, I am very grateful for all your help.
                      I am sure ill be in touvh soon to find out how to do something else
                      • happy_highlander
                        • 3535
                        #116
                        You are very welcome the first one you do always takes while,,but you will soon be doing all your mates (That whole process should take about 20 mins ) have fun
                        • Beccy
                          • Feb 2012
                          • 54
                          #117
                          thanks again
                          • Dawlan
                            • Jan 2013
                            modmii 4.3.4
                            I can't get Just dance 3 to work on my Wii, I will try the softmod update and see if this works
                            • Keithuk
                              • 2264
                              #119
                              Welcome to DK.
                              Well all 8 of the Just Dance games work for me. You need to post a sysCheck report as instructed in that link so we can see which IOS's are installed.
                              Happy New Year.
                              Keith
                              2010 Golf GTD (170)
