ok no problem press the wii button in the bottom left corner then select wii settings then internet then connections settings then select one that says none probably teh first one then wireless connection then search for access point then pick your wifi network and put in the password the nsave the settings then test the conection
Remove crack from WII
you ready for the next bitComment
yes load it and let it completeComment
ok now to change your system menu and remove darkcorp all in one foul swoop......launch hbc and select mmm it should say in the top right you are on ios 236 if not then using the wiimote navigate down to reload with another ios and select 236 from the list then go to wad manager and press a to select. then select all wads for batch install used to be the number "1" on the wiimote but may be done by holding down the "+" button for 2 secs after all the wads are marked by whatever method works press "a" twice to install them and make sure they all install without errorsComment
Excellent you have just succesfully softmodded your wii now onto priiloader for extra protection exit mmm and launch priiloader from hbc and install it when it's done switch off the wii and take the sd to the pc and rename the bootmii folder to bootmii1Comment
just in case you were wondering
