Remove crack from WII
  • Beccy
    • Feb 2012
    • 54
    #61
    yes it has
    • Keithuk
      • 2264
      #62
      Originally posted by Keithuk
      Ok if your doing a NAND backup
      I've just given you a link for doing the NAND backup procedure watch the video.
      There is another link underneath I've posted How to back your nand and install priiloader
      So you now have a Launch Bootmii button as you exit HBC?
      Keith
      2010 Golf GTD (170)
      • happy_highlander
        • 3535
        #63
        Originally posted by Beccy
        yes it has
        woo hoo your as safe as houses now,,, switch off the wii and take the sd card out the wii and and put it in the pc you now want to create a folder on the pc called darkcorp nand backup and save the bootmii folder, the boot.elf file, the bootmini.elf, the nand.bin and the keys.bin into it. Then switch the wii back on and put the sd card into it after it is on not before
        • happy_highlander
          • 3535
          #64
          So you now have a Bootmii button as you exit HBC?
          will you please stop trying to confuse things she is doing fine and doesn't need to mess about with bootmii ios...She has the privilage of having bootmii as boot2
          • Beccy
            • Feb 2012
            • 54
            #65
            I have copied them all into a folder. Should I also leave them on the SD card or remove?
            I am thinking I leave them on but thought better check
            • happy_highlander
              • 3535
              #66
              yes leave them where they are for now...Is your wii connected to the internet????
              • Beccy
                • Feb 2012
                • 54
                #67
                I dont think so as I think the retarded ex disabled all that so there were no updates done
                • Beccy
                  • Feb 2012
                  • 54
                  #68
                  wii on and sd card inserted
                  • icepick
                    • 198
                    #69
                    When 'your' a noob although welcoming all the help given, it can be confusing with 'conflicting' advice.
                    Back when I started, I followed One memembers advice and stuck to it (that way both parties knew at what stage 'one' was at !)
                    Without being disrespectful to people 'only trying to help'
                    Regards
                    • happy_highlander
                      • 3535
                      #70
                      do you know how to connect it to the internet...It's not really essential but makes the next bit easier...I can walk you through it if required assuming you have wifi available
                      • Keithuk
                        • 2264
                        #71
                        Rather that flicking the SD card in and out everytime you want to use the Wii you could rename the [bootmii] folder on the SD card to bootmii.old then it won't look for it when your Wii starts up.
                        Keith
                        2010 Golf GTD (170)
                        • Beccy
                          • Feb 2012
                          • 54
                          #72
                          yes i have wifi available.
                          ill give it a go, think its in the settings
                          • Beccy
                            • Feb 2012
                            • 54
                            #73
                            well ive had a look and really have no idea
                            by the way im not blonde just in case you were wondering
                            • happy_highlander
                              • 3535
                              #74
                              Right that's enough now....SHUT THE FCUK UP and read the whole thread after the softmod is finished and then make your stupid comments when you can't confuse matters
                              • Beccy
                                • Feb 2012
                                • 54
                                #75
                                I think ive done it
