Remove crack from WII
  • Keithuk
    • 2264
    #31
    Well we still don't know that much about your system. As I've asked please to a sysCheck.
    Originally posted by Keithuk
    I think your best bet at the moment is you post a sysCheck report and please follow the instructions in that link to post it in here, DON'T use NotePad to open it with WordPad.
    As we don't even know your HackMii (softmod software) version.
    Keith
    2010 Golf GTD (170)
    • Beccy
      • Feb 2012
      • 54
      #32
      Here is the system check.....
      sysCheck v2.1.0b11 by Double_A and R2-D2199
      ...runs on IOS36 (rev 1042).
      Region: PAL
      System Menu 4.0E (v418)
      Homebrew Channel 1.0.1 running on IOS36
      Hollywood v0x11
      Console ID: 71579511
      Boot2 v3
      Found 63 titles.
      Found 30 IOS on this console. 6 of them are stub.
      IOS4 (rev 65280): Stub
      IOS9 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS10 (rev 768): Stub
      IOS11 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS12 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS13 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS14 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS15 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS16 (rev 512): Stub
      IOS17 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS20 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS21 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS22 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS28 (rev 1288): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS30 (rev 1040): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS31 (rev 1040): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS33 (rev 1040): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS34 (rev 1039): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS35 (rev 1040): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS36 (rev 1042): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS37 (rev 2070): Trucha Bug
      IOS38 (rev 3609): Trucha Bug
      IOS50 (rev 5120): Stub
      IOS51 (rev 4864): Stub
      IOS53 (rev 4113): Trucha Bug
      IOS55 (rev 4633): Trucha Bug
      IOS60 (rev 6174): Trucha Bug
      IOS61 (rev 4890): No Patches
      IOS249 (rev 7): Trucha Bug, ES Identify, Flash Access, NAND Access
      IOS254 (rev 3): Stub
      BC v5
      MIOS v9
      Report generated on 2012/02/15.
      • Keithuk
        • 2264
        #33
        Region: PAL
        So it appears you ex installed Homebrew Channel 1.0.1 running on IOS36.
        Homebrew Channel so your 7 versions behind.
        It appears on the next version they added BootMii to the HBC home button probably thats why you can't see it.
        1.0.2
        • Added "Launch BootMii" button (BootMii IOS) to home menu
        If you install PriiLoader 0.7 then there is an option in there to access BootMii but after this length of time I don't think there is much point in backing up the NAND to include Darkcorp. I'm betting your ex didn't do a NAND backup when he did it?
        If you intend using USB Loaders you would nee to update some wads. If I remember your first post you just wanted it back to original.
        Keith
        2010 Golf GTD (170)
        • happy_highlander
          • 3535
          #34
          Region: PAL
          Hollywood v0x11
          Boot2 v3
          Found 63 titles.
          BC v5
          MIOS v9
          Ok now you have this we have another option...launch modmii and get to the main menu and select "su" then put the csv file syscheck created into modmii and this will download all the files you need to update the softmod....Looking at the files modmii has been supplying it should remove darkcorp while updating...
          Edit scratch all that lot before you go any further I'm going to write you a tutorial on how to remove darkcorp. It may take a bit more time but is going to be the safest method of getting your wii working again
          • Beccy
            • Feb 2012
            • 54
            #35
            Okey dokey. I'll wait for you to get back to me with tutorial. Sorry for taking up lots of your time. I really do appreciate this
            • happy_highlander
              • 3535
              #36
              You cannot remove darkcorp by the normal method as you have preloader not priiloader installed and this will corrupt during removal leaving you no brick protection....You would be required to install a new system menu to remove preloader but you don't have bootmii installed either as an ios or as boot2 so we are back to square one....The only option you have is to do the full softmod starting from the beggining and use bannerbomb to reinstall bootmii selecting install as boot2 and as ios you can then do a nand backup and if that is successful you have a better chance of recovery if the wii bricks while trying to install priiloader over preloader...So if you don't mind we will go from the start...Are you ready
              • Beccy
                • Feb 2012
                • 54
                #37
                I am totally ready but remember go easy on me as not technical at all
                • happy_highlander
                  • 3535
                  #38
                  no problem remember this is still going to be a bit iffy due to the fact it is a very early version of darkcorp and has screwed the system files completely...This may still brick but you don't have many options with bit of luck we will get bootmii installed and a nand backup done and then we can uncross everything..First off put the sd card into the wii that you put all the files on from modmii and launch hbc then select mmm (multi mod manager) once that loads navigate down t oapps manager and select the hackmii installer and run it
                  • Beccy
                    • Feb 2012
                    • 54
                    #39
                    I have done that. do I press 1 to continue?
                    • happy_highlander
                      • 3535
                      #40
                      yes then install the homebrew channel
                      • Beccy
                        • Feb 2012
                        • 54
                        #41
                        it sayts sucess
                        then i pressed continue and I have options for
                        install hbc
                        uninstall hbc
                        bootmii
                        view copyright
                        exit
                        which next?
                        • happy_highlander
                          • 3535
                          #42
                          it sayts sucess
                          install hbc
                          uninstall hbc
                          bootmii
                          view copyright
                          exit
                          which next?
                          install bootmii as boot2 then again as ios
                          • Beccy
                            • Feb 2012
                            • 54
                            #43
                            thats done
                            • happy_highlander
                              • 3535
                              #44
                              thats done
                              If it allowed you to install as both then one more step and your wii is almost 100% brickproof.. Return to main menu then exit...Do you have 800mb of space on your sd card...if so launch hbc and press the home button the wiimote then select bootmii
                              • Beccy
                                • Feb 2012
                                • 54
                                #45
                                I have dont that. now have on screen 4x sd card shaped icons
