Wii 4.2E softmod tutorial. Easy to follow guide.
sounds like you didnt install the patched ios70,look in the wad folder of the 4.2 pack from the first page and install that with wad managersigpicComment
Just confirming that version of preloader worked a treat!
Have managed to get wii motion plus working as well on red steel 2, using the alternative .dol trick.
Loving this, thanks guys again for the brilliant tutorial!Comment
well done
Thanks for the tut ,, tried many others b4 i found this one and this has worked like a dream on the 4.2e , although the first game i tried to load using uloader gets to the start game then freezes with a black screen (monster hunter tri) any one got any ideas please ,, any help would be greatly appreciated , u
you need to start it with ios223Thanks for the tut ,, tried many others b4 i found this one and this has worked like a dream on the 4.2e , although the first game i tried to load using uloader gets to the start game then freezes with a black screen (monster hunter tri) any one got any ideas please ,, any help would be greatly appreciated , u
also your ios223 needs to be installed as 37 merged with 38Last edited by ck-ok; 22 May, 2010, 16:23.sigpicComment
thanks but bit lame and new to this Wii stuff
ok , thanks for that ck-ok , but bit naeve on how to do that , possible to give me a few brief instructions on how to do that please , thanks in advance
?Hi .Thx for an awesum guide, everything worked great.
I have a question.. i did everything except installed priiloader, my question: Is it safe to install it now after ? i installed bootmii as an ios and made a backup before i continued the guide if that mathers btw.
Help would be appreciated ,Thx
yes its safe to install preloader now if you dont then your nand backup will be useless without it?Hi .Thx for an awesum guide, everything worked great.
sigpicComment
Wii ver. 4.2U Black Wii
I'm a complete newbie doing this stuff. I have downloaded and copied to my SD card bannerbomb and hackmii installer as instructed. Even after trying all versions of bannerbomb it will not load on the Wii. All I get is a ?.
Any suggestions?
ThanksComment
what sd card are you using? it need to be 2 gig or less formatted to fat 32sigpicComment
try a different card 2gig verbatim is best,also read this http://sites.google.com/site/complet...its/bannerbomb its a bit more detailedLast edited by ck-ok; 25 May, 2010, 06:20.sigpicComment
Cheers ck-ok, but I'm not sure I put my question across properly. If you install priiloader does that automatically mean it will run in the background when you boot up the Wii or does it only run when you invoke the priiloader menu by pressing 'reset' as the Wii boots up?
edit: I've just double checked the settings and see that priiloader is set to boot to system menu by default, so I think it's fair to assume that it always boots up when starting the Wii and follows on into the system menu. That would also explain why my NTFS cISO is running on my PAL Wii.Comment
