in the multi mod manager?
Wii 4.2E softmod tutorial. Easy to follow guide.
This guide with Step by Step Pictures
Hey, thank you so much for this guide!!
I have posted it up on my blog with pictures of each step, I hope you don't mind.
I really found it hard to read the red text and some of the steps were not 100% clear so I thought others might benefit seeing what they should be seeing at each step.
Hope others find this useful.
I posted it as : wii 4.2 load backup games from usb hdd
I hope others might find the screen shots useful. I tried to match the step numbers up as much as possible and split steps 7 up into subsections and gave 7.1 its own page.
Cheers
Rob.Comment
Looks like your wii is not online, I'm not sure what your doing but network... net_init is abbreviation for network initialization failed.
Try the step by step guide with pics i posted above and let m e know what step you get stuck at.Comment
Sorry Sam i didn't scroll up enough to see this, if you can type out more of the error, is it possible you have already completed this step via another guide? if you try to continue with the next steps how far do you get.
More specifics on the error may help. i.e the sub step, the error and the messages just before and just after the error.
Rob.Comment
Any feedback on my picture version of the same wii 4.2E usb hdd tutorial would be good, thats so much to the original tutorial this made thie proccess so much easier.
My wii 4.2E usb hdd tutorial with the same steps here but with pictures.Comment
In which settings is the 002 fix?
I did the tut from the front page and used all the tools there. I used to Bomber to get HBC.
The first was a random Pal game i grabbed of newsnet, the second pal game was Mario galaxy 2 none worked, both gave -2 error on load. I checked my wii to see if it was one of the unmodifiable wiis, the result was no. When i put a real game in Uloader in the corner it loads at 249, but when i put a backup in it loads at 222, not sure if that could be a problem.Comment
when you select a game in uloader at the bottom there is a configure button click on that and you can change disc booting settings keep trying untill you find what worksIn which settings is the 002 fix?
The first was a random Pal game i grabbed of newsnet, the second pal game was Mario galaxy 2 none worked, both gave -2 error on load. I checked my wii to see if it was one of the unmodifiable wiis, the result was no. When i put a real game in Uloader in the corner it loads at 249, but when i put a backup in it loads at 222, not sure if that could be a problem.sigpicComment
did you follow tut word for word allway through?
what discs are you using and burning software are you using?sigpicComment
