Wii 4.2E softmod tutorial. Easy to follow guide.
  • Samfisher84
    • 5
    #676
    in the multi mod manager?
    • short360uk
      • 313
      #677
      sorry i thought u meant in trucha bug restorer
      • Banny706
        Does this work with a 4.2U Wii?
        • Samfisher84
          • 5
          #679
          How do i use that one the ios36 or 15?
          i got this error
          Initializing network…net_init failed: -116
          Error reading IOS into memory
          • robmulally
            • 16
            #680
            This guide with Step by Step Pictures
            Hey, thank you so much for this guide!!
            I have posted it up on my blog with pictures of each step, I hope you don't mind.
            I really found it hard to read the red text and some of the steps were not 100% clear so I thought others might benefit seeing what they should be seeing at each step.
            Hope others find this useful.
            I posted it as : wii 4.2 load backup games from usb hdd
            I hope others might find the screen shots useful. I tried to match the step numbers up as much as possible and split steps 7 up into subsections and gave 7.1 its own page.
            Cheers
            Rob.
            • robmulally
              • 16
              #681
              i got this error
              Initializing network?net_init failed: -116
              Looks like your wii is not online, I'm not sure what your doing but network... net_init is abbreviation for network initialization failed.
              Try the step by step guide with pics i posted above and let m e know what step you get stuck at.
              • robmulally
                • 16
                #682
                I tested it with 4.2E and it was ok.
                • robmulally
                  • 16
                  #683
                  Hi everybody!
                  I got the 4.2E but cant seem to do
                  4. Press down then press A to select ?Install and patch IOS36.?
                  When i do that i get errors, cant downgrade and such?
                  Any pointers on why that is?
                  Sorry Sam i didn't scroll up enough to see this, if you can type out more of the error, is it possible you have already completed this step via another guide? if you try to continue with the next steps how far do you get.
                  More specifics on the error may help. i.e the sub step, the error and the messages just before and just after the error.
                  Rob.
                  • robmulally
                    • 16
                    #684
                    Any feedback on my picture version of the same wii 4.2E usb hdd tutorial would be good, thats so much to the original tutorial this made thie proccess so much easier.
                    My wii 4.2E usb hdd tutorial with the same steps here but with pictures.
                    • havoknrg
                      • 6
                      #685
                      Hi there thanks for the great Tut. But i seem to have a problem, I have burned 2 DvDs and yet when i try to run them with Uloader I get "Error -2" can anybody help
                      • ck-ok
                        • 2592
                        #686
                        dont know what loader your using but try switching 002 fix on in settings.
                        what games are they?
                        • havoknrg
                          • 6
                          #687
                          In which settings is the 002 fix?
                          I did the tut from the front page and used all the tools there. I used to Bomber to get HBC.
                          The first was a random Pal game i grabbed of newsnet, the second pal game was Mario galaxy 2 none worked, both gave -2 error on load. I checked my wii to see if it was one of the unmodifiable wiis, the result was no. When i put a real game in Uloader in the corner it loads at 249, but when i put a backup in it loads at 222, not sure if that could be a problem.
                          • ck-ok
                            • 2592
                            #688
                            when you select a game in uloader at the bottom there is a configure button click on that and you can change disc booting settings keep trying untill you find what works
                            • havoknrg
                              • 6
                              #689
                              When I put the "back up" DVD in it just has error -2 at the top, not buttons to press to change or edit.
                              And thanks for the help man, it has been very quick, can't fault you
                              Edit: just a button to go to wii menu.
                              • ck-ok
                                • 2592
                                #690
                                did you follow tut word for word allway through?
                                what discs are you using and burning software are you using?
