Wii 4.2E softmod tutorial. Easy to follow guide.
  • dell_xps
    • 2558
    #61
    Originally posted by treble
    hi many thanks for this at first a game worked without your add on but just tried another it wont work i have added your bit to the sd card i located it using wad manager then ios15 but it doesnt network load just says sd card or usb what have i done wrong thankyou
    it asks if you want to install from wad, when you push the control right it brings up network.
    HTH
    • dell_xps
      • 2558
      #62
      Originally posted by rizzurp
      great instructions, worked perfectly. going to try mario edit tonight. thanks!
      Yes leave feedback m8, always good to let people see it does work.
      Ta
      • treble
        • Mar 2009
        • 9
        #63
        HTH
        hi i click on wad manager thenselect ios version to use then ios 15 then select source device but no network am i just being numb?
        • dell_xps
          • 2558
          #64
          Your doing it wrong bud, put the cIOS on your SD card, in the Apps folder make a folder called CIOS15, inside there put the cIOS 15 file, now rename that to boot.dol......
          Now...................
          open up homebrew channel, locate the cIOS15 folder, select it.
          Job done.
          • treble
            • Mar 2009
            • 9
            #65
            Job done.
            i thought i had done that if i open up the sd card i have an apps folder that i made then in that i have boot.dol then in that there is
            cIOS r15 installer
            • dell_xps
              • 2558
              #66
              cIOS installer, you rename that to boot.dol m8.
              Apps on route of SD card, inside Apps have a folder called CIOS15, then inside that put the cios installer, once in there rename the installer to boot.dol
              Now open homebrew channel, locate the CIOS15 folder and select it, then install it via network.
              • treble
                • Mar 2009
                • 9
                #67
                i give up mate its having none of it thanks for your help anyway
                • dell_xps
                  • 2558
                  #68
                  Gimme 30mins m8 and i'll upload all the files you need ok.
                  X Factor is on (saddo) so i'll do it asap.
                  • dell_xps
                    • 2558
                    #69
                    ok unrar the file to your sd card, Apps should be the main folder you see when you click on the SD card ok, then pop it in yer Wii.
                    • rizzurp
                      • 6
                      #70
                      Ta
                      hmm...
                      4.2e
                      successful cio15 install from network (great music, haha)
                      new super mario bros. pal
                      disc burned 2x with nero on verbatim dvd-r
                      in uloader, the upper left corner says cios222 whil reading, results in ?disc error? and then have to turn off console holding power button
                      i?m missing a step or the ?backup?is bad... help when you get the chance, thanks!
                      • dell_xps
                        • 2558
                        #71
                        Yup you have to use 249 m8. (go into the menu select pal 50 or 60, use ios 249), it does tell you this in post 1 m8.
                        HTH
                        "4.Once installed make sure you still have the uloader on your SD card, click on ULoader in the Wii channel, press 2 to launch from DVD,select ios 249,Pal 50 or 60 works, then load the game, should be working no problem".
                        • treble
                          • Mar 2009
                          • 9
                          #72
                          ok i dragged and dropped that file into the apps folder then homebrew channel then wad manager 1.5 then ios15 then it says select source device wii sd slot ,usb mas storage,usb 2.0 mass storage,sd gecko slot a ,slotb.but no network option im stuck
                          • rizzurp
                            • 6
                            #73
                            HTH
                            thanks for the reply!
                            when using the backup of mario bros., uloader doesn?t give the option to change ios or pal. the disk spins until it says dvd error.
                            i tried using a different disk to first change the settings, then put in the smb disk. still same problem even on 249, pal 50/60.
                            any other suggestions? thnx
                            • dell_xps
                              • 2558
                              #74
                              Gotta be the discs your using m8.
                              What make of discs, DVDRs or DVD+R ?
                              What prog did you use to burn it ?
                              Get a disc that did work b4 and get into the menu you'll see that you can change options.
                              • dell_xps
                                • 2558
                                #75
                                M8, forget wad manager !!! just open up the homebrew channel, as soon as you do this you'll see the cios15 folder, make sure your connected to the net, then click on it, select from network.
                                We'll crack this by the end of the day, lucky I'm off today
