It doesn't say 4.3 on page 1. This thread is over 12 months old so things have changed since.
Originally posted by ck-ok
Use this program to easily, automatically and legally set-up your SD card with the required files to fully softmod ANY Wii, and up/downgrade to firmwares 4.2, 4.1 and 3.2 (Support for all wii's: U,E,J,K and even Region Changed Wii's)
Sorry, me again. I've finished that part all OK, but now trying to get a hard drive to work.
I have a Kingston 8gb drive which is seen, so i know what it should do.
But when I plug my "Maxtor Personal Storage 3100 300GB" which is listed in the compatible drive listing USB Devices Compatibility List - WikiTemp
it just reboots. I have tried plugging into both ports, with and without the "COPY_TO_USB" files and plugging it in once I load the USB loader program.
The drive is formatted as NTFS and is full, so I don't want to format until I know it is going to work.
Any help would be most grateful as I don't want to buy a new drive is possible.
Hi Will this hack allow DVD video playback on black Wii running 4.3E, or is something else required? Is DVD video playback even possible on these newer devices? Thanks in advance...
This hack won't but you could try WiiMC on your SD card and run it from HBC, if it plays the DVD you could install the forwarder channel from the Download section on there.
