Boot to Freestyle Dash with Dashlaunch..?
  • roryson
    • Mar 2009
    • 694
    #106
    do i select configure usb device?
    • roryson
      • Mar 2009
      • 694
      #107
      if things dont go right, i have a 640gb hdd in my ps3 which i could put in my xbox if i format it right
      • cunny
        • 4915
        #108
        Originally posted by AgentD
        The usb drive needs a partition installed on it along with a file system which the xbox does when it formats.
        There may be another way to do it but I'm not aware of it.
        I believe this is what is causing you problems.
        edited to add
        your external usb drive
        I have mine setup another way. I have my games on my external hdd running from usb. I setup dashlaunch and fsd from my xbox hdd. At the time I set my usb on fat32 I was not using ftp to transfer things over.
        All runs fine here with my setup
        • roryson
          • Mar 2009
          • 694
          #109
          Agent, if your xbox formated your external drive, did u have to ftp your games across because of the file system on the drive.?
          • AgentD
            #110
            I've always transferred games or files from pc to usb. I haven't ftp'd anything to my console.
            Cunny's last post would suggest its not necessary to format usb drive from the console but what concerns me is your usb drive causing the console to freeze
            • cunny
              • 4915
              #111
              And going a little further on that Agent would be to either try another USB HDD or USB Enclosure.
              So i got FSD running from 60 XBOX HDD
              Games on a USB hdd with 500gb drive.
              I just reset dashlaunch tonight with your settings from launch.ini an it runs but i cant get it to boot to NXE only from console settings.And i lost all my covers. Oh the fun of it
              • AgentD
                #112
                I have fsd running on 20gb hdd with games on a 500gb usb also
                If you hold the right bumper while you boot or return to dash it will go to nxe dash
                • cunny
                  • 4915
                  #113
                  Which version dash do yo have?
                  As my launch.ini will have to differ from yours.
                  BUT_X = Hdd1:\Content\0000000000000000\FFFE07DF\
                  BUT_X = Hdd:\Content\0000000000000000\C0DE9999\00080000\C0 DE99990F586558
                  The top 1 is mine. Not correct as can go further just showing the difference. So unsure where to launch mine from
                  I'm running a freeboot for version 2.0.14699.0 (glitched)
                  • AgentD
                    #114
                    I'm still running 2.0.13599.0(jtag) purely beacuse I haven't had to update it yet, all games are still working
                    FFFE07DF - Is that the optional media update?
                    holding my x button boots xex menu (C0DE99990F586558)
                    If you wanted to boot into NXE as default, you could leave that line blank
                    Default =
                    Also worth noting that although when I navigate with xexmenu my xbox hdd shows as hdd1 but in my launch file I only use hdd for it to work
                    • roryson
                      • Mar 2009
                      • 694
                      #115
                      right, im ready to install dashlaunch but there is 1 thing i need help with. cunny said dont dissable LIVE within dashlaunch because he had trouble downloading covers. so in the launch.ini do i set liveblock = true and change it to false..?
                      • cunny
                        • 4915
                        #116
                        No leave it true. Dashlaunch will ask about blocking LIVE dns just dont allow that option
                        • roryson
                          • Mar 2009
                          • 694
                          #117
                          ive just installed dashlaunch and XEX menu loads with presssing X but NXE wont boot with left bumper, any ideas?
                          • AgentD
                            #118
                            The right bumper boots into NXE, not the left
