will a factory re-set get rid of all problems
  • footycard steve
    • 778
    #91
    got to have a break my head is throbbing,i'll check to see if more advice added in the morning and try it again then.
    • Cod3waX
      • 1011
      #92
      that whole startup before u see the windows logo screen is the boot sequence
      on that sequence there will be a line of Press any key to boot from cd-r
      so u hit anykey and the installation process will start
      • footycard steve
        • 778
        #93
        i've tried at least 6 times booting up,the first time the screens had loaded too fast before the disc tray opened as it doesnt run the memory test as before,i kept the disc in and re-started pressed s but it just goes to next screen i've also tried pressing other letters but it just continues to next screen,i only get the screen that says press f10 to configure not boot from cd, theres a screen that gives all the computer spec and i managed to pause it on that screen as i noticed it was saying something about boot cd not found, the screen at the top has MAIN PROCESSOR(R) PENTIUM(R) 4CPU
        it then has a large box with all the info like floppy disc etc etc first thing on top left of screen says 1ST MATH PROCESSOR: BUILT IN
        at the bottom of the screen under the big box it says
        DDRAM AT DIMM#1,2,
        SEARCHING FOR BOOT RECORD FROM CDROM.....NOT FOUND
        SEARCHING FOR BOOT RECORD FROM IDE-0
        then it just continues to load to the screensaver/desktop.
        the last try i held down a letter and pause break to try and hold the first loading page but it went to the next screen making a constant beep which only stopped when i pressed the f10 to configure, should i try that old version of xp left by the repairer who conned me and see if that gives me the option to boot from cd or if i do will i have to go through the whole process of running it?
        • footycard steve
          • 778
          #94
          got the manual it says hermes 650 series inner page says msi ms-6232(v1.x) barebone, got the advanced bios page open for 1st/2nd/3rd boot device
          it says the items allow you to set the sequence of boot devices where AMIBIOS attempts to load the operating system.the settings are
          IDE-0 the system will boot from the first HDD
          IDE-1 the system as above 2nd HDD
          IDE-2 as above 3rd HDD
          do we not have IDE-0 set as 3 rd option with the sony at 1 and 2 or am i just confused. along with the manual i have 4 discs from the first time it was set up but i think they were for the scanner and the old screen and keyboard 1) blueline 1.2 cherry (has pic of keyboard on it)
          2) drivers and utilities has small writing on the edge these functions are optional,on the disc in a box it has adobe,adobe reader,fuzzy logic,live update,pc alert,pc-cillin,useful websites.
          3)ulead photo express (will this be for my scanner)
          4) fax talk (looks like for modem)
          • Cod3waX
            • 1011
            #95
            yes try that disc see if the option of boot the disc comes up
            basically what should happen is the computers motherboard loads first then then cpu n ram and then will check for devices and should check the cd rom first and load the disc
            if its failing to see the disc it will then continue to the next device which is the hard drive
            • footycard steve
              • 778
              #96
              i put that old vesrion xp disc in and i just pressed the h key and i did get the option to boot from disc.
              • Cod3waX
                • 1011
                #97
                i got an idea
                use ur the old xp disc get to the press any key and do it then let it load until it asks u to input a command
                at this point change the disc over and continue with the install
                • footycard steve
                  • 778
                  #98
                  Originally posted by Cod3waX
                  i got an idea
                  i've just tried switching the disc after hitting any key from boot from cd option whilst it was loading the windows set up screen but it says please insert the disk labelled windows xp professional cd-rom into drive a then press enter,if i wait until later in the set up procedure wont the same happen?
                  • Cod3waX
                    • 1011
                    #99
                    wait until it finishes loading b4 u change the disc
                    it will get to a screen where u have to input a command for it to continue
                    this is chance that it will mite work trying it this way
                    the disc i have supplied you mite not be working i should have booted up on start-up
                    • footycard steve
                      • 778
                      #100
                      before your last reply i changed the bios hdd order and tried the disc but again no boot from cd option,anyway i just let the computer boot and tried to load the disc from there but it failed to extract all of the files this time came up with an error something about cylic.
                      • Cod3waX
                        • 1011
                        #101
                        i will send u another 1 and use a different computer to burn it
                        sorry about that
                        • footycard steve
                          • 778
                          #102
                          sorry about that
                          is that what you think is stopping it from loading properly,i might as well just wait for the new disk before i try anything?
                          • Cod3waX
                            • 1011
                            #103
                            yea it will be that sorry again should have tested
                            have new disc now tested working and does not need a product key ever
                            will post tomorrow morning
                            • aarias
                              • Jul 2012
                              • 14
                              #104
                              fresh install, or use ccleaner to clean your registry, it should make a significant change, or you could install a TuneUp free trial version tu fix some other troubles.
                              • footycard steve
                                • 778
                                #105
                                have the replacement disk and now have it installed (i think) have managed to download avg free and spybot and currently running a spybot search,been on with it since 10-30 this morning and not hit any problems yet but i've not been online other than to download the anti virus etc but so far so good.
