Huawei E5830, E5832 & E5838 Free Unlock
Troubles with unlock
Hi there
now I have different problem. When I'm trying to read ESF, just after typing name of file and pressing Save, QMAT crashes. I tried three different cmputers with Win7 and Win764, but no result. Newer version of Qmat ? RevSkills ? works, but can't connect to modem. Any good idea about it?
Brg, LapiovraComment
after couple of tries...
RevSkill gave me those results ? no unique figure inside
Attached FilesComment
And in the end...
So, I've updated firmware!
after that QMAT worked and gave result. But inside SO MANY different 8 digit numbers... plz, helpAttached FilesComment
Good, sehr gut, Woldemar. It's unlocked now. Thank you very much.
But data connection is not working. 3G connected, no data. Looks like old operator data is not compatible with other one. And in the web interface no sign of setup. Any advice?Comment
You'll need to flash generic firmware to it or use it via USB. The web interface is often disabled on branded devices!
Be aware that this will almost certainly void your warranty!
All the files you'll need can be found here:
DC Files - Huawei E5832sComment
HI many thanks for this thread , I worked great ( first 8 bytes decimal found with 0101 precedingComment
Hey there. I've searched through the extract, but after trying two codes that didn't work, I though I'd put the extract up here to try and get a better result.
Your file is too large!
I'm guessing you've read the device incorrectly!
Retrace your steps it should be around 700K or so!!Comment
Hi Jim,
Thank you for the prompt reply! I've retracted my steps (twice). The resulting file on both occasions is 1.56MB.
Is this information of any assistance?
Device: Huawei E5832S
Network: O2 (Ireland)
IMEI: 354104033053143
Software version: 956.11.88.04.309sp01Comment
The information is of no use as calculators do not work!
I suggest that you try on another PC ideally with Windows XP 32bit running!
Ensure all modem dashboard software is closed down and re-run the procedure.
We have successfully unlocked quite a few E5832S, I we know it works!Comment
The QMAT version I have has errors during read EFS...
Network: Globe (Philippines)
IMEI: 354104034366445
Software version: 956.11.109.02.309sp01
Do I need to change software version to : 956.11.17.05.309 from (E5832sUpdate_956.11.17.05.309.zip) so that QMAT will work?Comment
