Huawei E5830, E5832 & E5838 Free Unlock
Need unlock code1
Please help! Need unlock code!
http://dl.transfer.ro/E5832s-transfer_RO-20feb.rar
Thanks,Last edited by espidi; 21 February, 2012, 06:36.Comment
Unlock Code: 40460924Comment
Help
My list of codes is
48867315
89401011
10260701
11111111
58853588
32265545
52534886
04670057
45852411
11470734
04638780
12222483
68264234
71021084
15408502
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
12345678
12345678
12345678
12345678
13551150
13551150
13551150
13553008
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
Shall I use the first one as it has 01 01 in hex before (2 dots)?Comment
Thanks @MKAlex !
I have another problem now.
I installed the latest firmware "Netvigator" ( E5832sUpdate_956.11.17.05.309 ) and in configuration page ( 192.168.1.1 ) can not change the profile, not the option area. Must select the profile for Vodafone RO.Comment
I have no idea as you didn't post your EFS file! This is just a list of numbers without the EFS file!!My list of codes is
48867315
89401011
10260701
11111111
58853588
32265545
52534886
04670057
45852411
11470734
04638780
12222483
68264234
71021084
15408502
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
13551150
12345678
12345678
12345678
12345678
13551150
13551150
13551150
13553008
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
The firmware is locked, so you'd need to upgrade to unbranded firmware!
This is not without risk, if you mess it up then you have a dead modem!!
If you would rather play safe, use the modem in USB mode!Comment
How do I connect in USB mode?
Strange is that with a Orange RO sim card works. On this network was originally blocked.Comment
Plug the modem is as if it were a normal Huawei USB modem. The device should install Mobile Partner.
There are two locks, one is the SIM lock that the code has removed. The second is the firmware which is doctored to permit only one set of network settings!Comment
Device does not install Mobile Partner. When you connect to the USB still running Orange RO specific software. I downloaded from internet the Mobile Partner software and I installed. The problem is I can not set the Vodafone RO in Mobile Partner, not keep the settings.
L.E. Can someone post a list of available firmwares for E5832s?
I saw a firmware from UCell (possible from Russia). This firmware is compatible with Romanian network settings.Last edited by espidi; 21 February, 2012, 13:17.Comment
Dashboard and Firmware are both available here: DC Files - Huawei E5832sDevice does not install Mobile Partner. When you connect to the USB still running Orange RO specific software. I downloaded from internet the Mobile Partner software and I installed. The problem is I can not set the Vodafone RO in Mobile Partner, not keep the settings.
I saw a firmware from UCell (possible from Russia). This firmware is compatible with Romanian network settings.Comment
Yes, the firmware on the site given is generic and will require you to enter the appropriate settings!
Be aware that doing something stupid during flashing can render your modem useless! So, if you get power outages use a laptop for example or if your PC crashes regularly for no reason then use a stable PC for the upgrade!!Comment
Thanks, i have this firmware (956.11.17.05.309) is for Netvigator. I looking for Ucell firmware.Dashboard and Firmware are both available here: DC Files - Huawei E5832sComment
Will it work even if the device is network-branded?Yes, the firmware on the site given is generic and will require you to enter the appropriate settings!
ThanksComment
