Huawei E5830, E5832 & E5838 Free Unlock
  • paca100
    • Feb 2012
    • 7
    #106
    Try-out
    Originally posted by Jim.Mahoney
    This is a bit lengthy but it should produce your E5830, E5832 or E5838 unlock code for free!
    Always REMOVE the SIM card before doing the read or you may get an corrupt file!
    Instructions:
    Download this version of QMAT.
    Digital Kaos - Downloads - QMAT
    Select the Application port of the E583x. Check in Windows Device Manager if unsure.
    To test if you got the right port, send the "00" version command.
    You should see something like this:
    Then select: Read EFS and flag "Alternative Method".
    Click "Let's go".
    The resultant file contains both Binary and ASCII characters.
    You will need to search for this for your 8 digit unlock code. There will be two codes in the file one is for removing the SIM lock and the other removes the Mi-Fi lock.
    You can use Notepad to search the file, its crude but you should find the code in a few minutes. I have tried a program called ExtractText:
    Windows 95+ programs
    The results are hit and miss with this program, sometimes the code is on the last line sometimes it is at the top of the list! However, it might give you a good idea of what you're looking for! To cut down on unnecessary searching using Extract Text go to Options and then Text Options and set the parameters to: Minimum Character 7 and maximum characters 8 plus you should have only Numbers selected:
    One thing to keep in mind, the unlock code will appear only once so you can ignore repeated codes. This should narrow the search down somewhat!
    Example:
    Do remember that you have 10 attempts to enter the correct code so do take a little time to chose the code!
    A code entry to is included below....
    If this seems complicated please ask someone else to do the task for you!
    Please post your results!
    I will try and see if it works for me......
    • Jim.Mahoney
      • Feb 2010
      • 4249
      #107
      Did you really need to Quote the first post?
      • paca100
        • Feb 2012
        • 7
        #108
        No, my mistake
        • paca100
          • Feb 2012
          • 7
          #109
          Help!
          Jim, it has worked fine for me until I get the numbers, I honestly dont know which one is it
          • paca100
            • Feb 2012
            • 7
            #110
            Help!
            Another thing, when I open CardLock_Unlock I always get the message "Data Card Not Found!"
            Any ideas?
            • paca100
              • Feb 2012
              • 7
              #111
              File
              May be if you see the txt I get......
              • Jim.Mahoney
                • Feb 2010
                • 4249
                #112
                Without your EFS file, its impossible to verify your codes!
                • paca100
                  • Feb 2012
                  • 7
                  #113
                  sorry again.....
                  • Jim.Mahoney
                    • Feb 2010
                    • 4249
                    #114
                    sorry again.....
                    I am not sure why you have posted this again?
                    I need your EFS file which is around 700 - 750K in size unZipped.
                    • paca100
                      • Feb 2012
                      • 7
                      #115
                      Is this the one?
                      Should be.....this one?
                      • Jim.Mahoney
                        • Feb 2010
                        • 4249
                        #116
                        Your unlock code is: 17241373
                        • davlemag
                          • Feb 2012
                          Just waiting for registration to download the software...
                          • jjcc
                            • Feb 2012
                            #118
                            Guys, Need help in unlocking e5832
                            I got 1.23Mb EFS file after scanning
                            and 340bytes 8-digit numbers txt file after using extracttext
                            showing these numbers:
                            11111111
                            07257072
                            31053383
                            37414017
                            60305027
                            60673023
                            08821462
                            64431638
                            88266021
                            77818305
                            72832332
                            36061872
                            13553003
                            16035363
                            11628010
                            13553003
                            13553003
                            13553003
                            13553003
                            13553006
                            13553006
                            12345678
                            12345678
                            12345678
                            12345543
                            13553003
                            13553006
                            13553003
                            13551150
                            13553003
                            11111111
                            11111111
                            11111111
                            51097044
                            I already tried 07257072 and 31053383 but it's not working
                            Using win 7 and cannot find someone who uses XP.
                            • jjcc
                              • Feb 2012
                              #119
                              Update:
                              The last code unlocked the modem
                              thanks for this post
                              • smallk
                                • Feb 2012
                                thanks for share ~
