loaded latest u/w re-formated cam and configuered box but no conax channels openning, can only get nagra channels, is this the end for the diablo and programmer? cheers
Diablo Cam Underworld Files
dish100 13.0?E-4?W <>Jepssen SB-5
dish125 motor 45?W ->68.5?E <> Jepssen ST-2 HD
Diablo cam 2.3Comment
^^^ Version: UnderWorld 1.74 ^^^
^^^ ReLeasE Date: 05/05/2009 ^^^
^^^ Working on: ^^^
^^^ ? Diablo CAM Light 2.2 /2.3 ^^^
^^^ ? Diablo CAM Wireless 2.2 /2.3 ^^^
^^^ ? Diablo CAM Wi-Fi 2.3 ^^^
_____________________________________________
What's New??
Now Diablo read the TNT Viaccess card
Updated all the emulator working:
?Version 2.3 ONLY? Irdeto2: Canal Digitaal Holland - Astra (19?E)
?Version 2.3 ONLY? Irdeto2: Euro 1080
****expiration date extended to 1 monthAttached Filesdish100 13.0?E-4?W <>Jepssen SB-5
Hi all, i programmed u/w174 but still not opening channels, i had to use softcam to get digi tv, any ideas why diablo isnt
doing the job. cheers.Comment
underworld 175
^^^ Version: UnderWorld 1.75 ^^^
^^^ ReLeasE Date: 12/05/2009 ^^^
^^^ Working on: ^^^
What's New??
Great news for Diablo WiFI and CCCam Lovers
now Diablo WiFI can works also with new servers 2.1.1
XclusiVe E M Us
Underworld Team wish you a great weekend enjoing this big news:
Bouquet: Canal Digitaal - KingOfSat
?Version 2.3 ONLY? Conax: Canaal Digital Nordic - Thor 3/5 (0.8?W)
Exclusive MEDIASET Italia pre-paid card supported.
You can now use the Italian DTT card in the DiabloCam and it is now supported.
This is NOT Emulation but card reading and it will act like official Sanmsung, Panasonic etc CAMs.
YOU STILL NEED THE OFFICIAL SMARTCARD.
Via DTT you can watch all the channels including Calcio etc. - YOU MUST SUBSCRIBE (HAVE THE RIGHTS)
-Joi
-Mya
-Steel
-Disney Channel
-Grande Fratello
-Joi +1
-Mya +1
-Steel +1
-Disney Channel +1
WORKING ON 2.3 ONLY!
** THE BIG THING! **
** CCCam in Diablo Wi-Fi!! **
Finally available the CCCam protocol on Diablo Wi-Fi from UnderWorld 1.63.
What does it mean?? Freedom of using ANY receiver like a DreamBox.
Thanks to the Wi-Fi LAN embedded in the Diablo Wi-Fi when you connect it to
ANY Common Interface Receiver it will work like a DreamBox and enchances all the
s****ing features that DreamBox is offering in "exclusive" up to today but...
NOW with the big advantage that you can use you own Common Interface receiver
that you are familiar with and you like most, High Definition too!!
You can configure the CCCam as the DreamBox CCCam. You simply copy and paste the
same config string as you are using in your DreamBox.
Do not forget that even the other protocols are working as well like GBox, NewCamD and Radegast.
The Diablo Wi-Fi will act as card client or either Card Server!
You are not dreaming this is pure reality!
WWW
UUUU NNNN DDDDDDD EEEEEE RRRRRRRR WWWWW WWWWW W OOOOOOO RRRRRRRR DDDDDDD
UUUUUUU U NNNNNNN N DDDDD DDDDD EEEEEE E RRRRR RRRRR WWWWW WWWWW W OOO OOOO RRRRR RRRRR LLLLLLL DDDDD DDDDD
UUUU U NNNNNNN N DDDD DDDD EEEE RRRR RRRR WWWW WWWWW W OOOO OOOOO RRRR RRRR LLLL DDDD DDDD
UUUUU U N NNNNNN N DDDDD DDDD EEEEE E RRRRR RR WWWW WWWWW W OOOO OOOOO RRRRR RR LLLLL DDDDD DDDD
UUUU U N NNNNNN DDDD DDDDD EEEEEEEE RRRRRRRRRRR WWWWW W WWWWW OOOO OOOO RRRRRRRRRRR LLLL DDDD DDDDD
UUUU U N NNNNN DDDD DDDD EEEE E E RRRR RRRRR WWWWW WWWWW OOOOO OOOO RRRR RRRRR LLLL L DDDD DDDD
UUUUU U N NNNN DDDD DDD EEEE EE RRRR RRRRR WWWW WWW OOOOO OOOO RRRR RRRRR LLLL L DDDD DDD
UUUUU U NN NNN DDDD DD EEEE EE RRRR RRRRR WW WW OOOO OOO RRRR RRRRR LLLL LLL DDDD DD
UUUUUUUU NNN DDDDDDDD EE EEEE RRRRR RRRR OOOOOOO RRRRR LLLLLLLLLL DDDDDDDD
E M Us
(All Emus around at present)
[?] Nagra 1
[?] Nagra 2 - Edit keys with Keymaker
[?] Seca 1
[?] Seca 2 (not working but implemented)
[?] TPSCrypt
[?] Viaccess 1 and 2.3 2.4
[?] Irdeto 1
[?] Irdeto 2 - Supported keys needed but Xclusive Emus
[?] Cryptoworks Bios 3
[?] Biss
[?] Constant Control Word
0riginaL CardS Supported
(?) Betacrypt
(?) Irdeto 1/2
(?) Seca 1/2
(?) Viaccess 1/2
(?) Cryptoworks
(?) Conax
(?) DreamCrypt
(?) Nagravision 1 with BoxKey
(?) DGCrypt
IMPORTANT NOTICE!
Many people are reporting that Diablo is slower than other CAMs when you zap through
the channels (means change the channels). This can be true and can either be solved.
Diablo CAM is the only CAM in the market that has the AUTO-PMT function.
Let?s step back and explain what it is an how it works:
Every CAS (Encryption System) has its own ID number called CAID. This number can be
retrieved directly from the streaming (i.e. Seca is 0100, Viaccess is 0500 etc).
In any case the on most of the receivers (not all) the CAM has to declare which CAID
it is capable to descramble. The problems is not with systems like Seca or Viaccess
(unique CAID for all providers) but it comes with IRDETO what has multiple CAID numbers
starting with 06 XX where XX is a variable number. In this case the number of CAID
can be extremely high.The point is that in theory you could declare as many CAID as you
like but most of the receivers accepts just 16 CAID per initialization. All the CAMs
around have pre-configured CAID with the most popular descrambling solution.
Diablo is much more advanced!! It can retrieve the CAID information directly from Streaming!
The CAM needs to send some CAID to the receiver and get the streaming access. The if the
CAID is not one of the declared the CAM with declare the new one obtained from the Streaming.
This is a clever manner to void the above CAID declaration problem. This is not a
100% solution to the problem as some receivers won?t give you the access to the Streaming
if you did NOT declared the right CAID in the beginning! Fortunately this case is pretty
much rare and Diablo then refers to the CAID list.
ALL OF THIS MAKES A LOSS OF TIME WHILE ZAPPING! But it offers the maximum flexibility
for descrambling in Multi-Cas.
IF YOU WANT TO HAVE A FASTER ZAPPING SOLUTION: Then simply set the AUTO-PMT to OFF.
But remember: You have to set and declare the CAID you want to descramble in the CAID.XML
file in the CAM! This enhances you to the maximum (we can do even better) zapping speed
but you may loose CAS compatibility!
Remember: AUTO PMT is available on Diablo ONLY!
??O????O????O????O????O????O????O????O????O????O?? ??O??
??O?? HOW TO UPDATE THE CAM! ??O??
??O) Using the TwinBase
-Download the Twinbase Manager latest version from www.diablocam.com
-Download the user guide in english from www.diablocam.com and read it out to void further problems.
-Make sure you have the Framework 2.0 installed on your computer otherwise downloadit when requested from Microsoft.
-Install Twinbase Manager you previously downloaded.
-Go to "Upgrade Utilities" and insert the DiabloCam Wireless into the Twinbase.
-Press "UPDATE DIABLO CAM"
-Insert the file you want to load into the DiabloCam Wireless.
-Wait untill the END.
-Now insert the DiabloCam Wireless into the receiver.
??O) Using the CAS INTERFACE 2 / 2+Plus / 3 / 3+Plus
-Download Cas Studio 8.5 or higher (laterst version)
-Install Cas Studio.
-Go on CAM Programming.
-Follow the instructions untill the end.
-Now insert the DiabloCam Wireless or DiabloCam Light into the receiver.Attached FilesComment
hi,
Does someone haves this work propertly?
I wanna but this Ci interface.
Can someone tell me about his experience about this?
Many thanks in advance,
Jellybee007Comment
canal nodic on thor 1w has changed cas from cas 5 to cas 7
and is now not open with the diablo cam canal+ nl on astra 19e
is open and digi-tv on thor plus a few chns on sirus 4.8e
there has been posts saying more is comming soon on the cam files
so at the moment it's a wait and see if this happensPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
New underworls 176 some fixes in WIFI
Version: UnderWorld 1.76 ^^^
ReLeasE Date: 21/05/2009 ^^^
Working on: ^^^
What's New??
Fixed some troubles on wpa and wpa2 diablo WIFILast edited by benny/9; 29 June, 2009, 10:37.Please Read Carefully!
New Underworld 177 file 27/5/09
more fixes on Wi-Fi Diablo CAM Wi-Fi 2.3
What's New??
Wpa-Wpa2 association improved: it's automatic now. Encryption menu
lists only one wpa item: WPA-PSK + WPA2 PSK. It automatically supports
all possibilities of Wpa/Wpa2 and Tkip/Aes choosen in AP settingsLast edited by benny/9; 29 June, 2009, 10:37.Please Read Carefully!
New Underworld 178
^^^ Version: UnderWorld 1.78 ^^^
^^^ ReLeasE Date: 1/06/2009 ^^^
^^^ Working on: ^^^
What's New??
Improvments in CC*m...now works better
XclusiVe E M Us
?Version 2.3 ONLY? Irdeto2: Canal Digitaal Holland - Astra (19?E)Last edited by benny/9; 27 July, 2009, 11:28.Please Read Carefully!
^^^ Working on: ^^^
What's New??
XclusiVe E M Us
?Version 2.3 ONLY? Irdeto2: Canal Digitaal Holland - Astra (19?E)Attached Filesdish100 13.0?E-4?W <>Jepssen SB-5
