Blade Media 7000s patched firmware 05/01/2012 81x
  • delboy13
    • 415
    here is latest blade firmware
    fixed youtube,
    the default audio setting has been set to "high" (you need to reload your cdf for it to take effect)
    and the adult is hidden by default, 3641 toggles it on and off from the youtube/weather screen.
  • vorlon2257
    • Sep 2011
    • 356
    Thanks for this
    • zee24
      • 3342
      what do you mean by reload cdf file?
      • ramjet
        • 2995
        it means save the channel data file list to usb stick ( cdf file)
        factory reset and load the patch and factory reset again afterwards
        then reload the channel data file ( the cdf ) afterwards
        • zee24
          • 3342
          why do you need to factory reset twice?
          • zee24
            • 3342
            is the file which is in this thread the cdf file?
            • leon632
              • 129
              the cdf or cndf is the location of the channels, favourites etc.
              If you go to menu, utilities, download and press the red button it will save all your channels as when you factory reset it will get rid of them all. also make a note of any info on the 9991 menu as this will go aswel.
              I don't think you have to factory reset but it is recommended.
              Once you have factory reset loaded the new fw and reset again you can go back to the download section, reload your cndf file and all your channels should be back as normal.
              you will just have to put back in your 9991 info again.
              • zee24
                • 3342
                to be honest i don't really factory reset whenever i install new firmware coz it usually works fine without, as does this apart from the audio thingy its still the same so il do what you n ramjet have told me and thanks
                • leon632
                  • 129
                  All my audios are set to high now with this update just to let you know.
                  • zee24
                    • 3342
                    Yes works fine after a factory reset all audios are on 'high' this is the first time ive got Youtube working aswell.
                    Anyone know how to get radio working, is there an easy way of getting all the radio channels instead of having to search for them 1 by 1?
                    • ramjet
                      • 2995
                      the first factory reset clears the box ready for patching
                      after patching , the second factory reset "locks" the patch into the box
                      that is the absolute failsafe scenario and should always be done if you have any problems
                      however , if you just load the new patches and it works without a factory reset , or if you just do one factory reset only , then as long as it works dont worry about it
                      but the failsafe method of before and after patching is always the one that almost guarantees no issues
                      • ramjet
                        • 2995
                        a cdf is a Channel Data File ( look at the initials ) and is the channel list
                        therefore the list will wnd in dot c d f . ie:- .cdf
                        whereas the patched firmware (or original) is STB . which is dot STB
                        STB = Set Top Box , which is your satellite box , in your case the blade STB
                        so the suffix details what the file actually is , by using its initials
                        • zee24
                          • 3342
                          how do i get radio working? can i get all the channels at once instead of searching for them 1 by 1?
                          • ramjet
                            • 2995
                            press GROUP and select your satellite astra2 28.2e
                            then press the radio/tv button to get the radio channels up
                            these can be moved into order using the channel edit in your menu
                            having just tested it I found it would say NO CHANNELS if I was in a favourite group , so had to place it on the astra2 group before activating the radio button
                            after that it worked fine
                            hope that helps
                            • zee24
                              • 3342
                              cheers ramjet finally got radio to work for the first time since ive had the box. I was trying to do it from where you find Youtube, Weather and Radio, everytime i typed in the channel it would never find it
