Blade Media 7000s patched firmware 05/01/2012 81x
  • tom2josh
    • Feb 2012
    #61
    factory reset
    cheers thanks for the info
    • swifty
      • 63
      #62
      firmware
      dowloaded the latest firmware but it says corrupted im am using winrar do i need a different programme to unzip it
      • Manic01
        • 5117
        #63
        Winrar should be ok, but try 7zip also and it's free.
        • swifty
          • 63
          #64
          thanks for the reply but winrar says its corrupted were can i download 7zip
          • zee24
            • 3342
            #65
            works fine with my winrar
            • swifty
              • 63
              #66
              so dk veteran my winrar says its corrupted should i try winzip or another pc cheers
              • ramjet
                • 2995
                #67
                try another pc , or another winrar or winzip , or try 7zip which is free
                • zee24
                  • 3342
                  #68
                  delete the file from your laptop or PC that you've already downloaded, then try downloading it again, sometimes it doesn't work the first time
                  • Nav2010
                    • 103
                    #69
                    Am having issues with dis version my lines keep disconnecting and wo t reconnect the net wrks blade online wrks, only way to get lines wrkin is to factory reset and start fresh, everytime I turn box off same situation any ideas???
                    • zee24
                      • 3342
                      #70
                      u shud factory reset with every new firmware anyway.
                      factory reset the box, then put the new firmware on, then factory reset again to lock the firmware, then put ur line in and u shud be good to go.
                      • markdarlo
                        • 6
                        #71
                        hi guys, how do i enter the hidden cline menu? 9991 doesnt work cheers
                        • smoggie
                          • 863
                          #72
                          have u flashed the non patched firmware?
                          • markdarlo
                            • 6
                            #73
                            Hi, I had the old firmware on it 25/04/11 and I did a factory reset and put the latest firmware on. Now I can't enter hidden cline. Thanks for ur reply
                            • smoggie
                              • 863
                              #74
                              where did you get the latest firmware from?? blade online??
                              • markdarlo
                                • 6
                                #75
                                Got it from the blade media website and put it on USB stick and loaded it on the box. Then went to blade online and got 28e Astra channel list (Wales region). Cheers
