Blade Media 7000s patched firmware 05/01/2012 81x
  • BigfatPaulie
    • Dec 2011
    • 203
    #151
    Goto the channel BEFORE chan 1 on any group... Usually called epg or similar, press ok, or select so you are tuned to it, and wait for a couple of minutes. Your epg will now be populated.
    Sent using Tapatalk
    • bj1
      • 445
      #152
      Originally posted by johnjones
      Hi, I have updated firmware and used bladeonline and channel lists downloaded from this site, but only seem to get now and next on epg. Just cant get 7 day epg. Please can anyone advise me on what to do. I have read that I need to do a scan on a certain freq. How exactly do I do this scan please. Sorry, I am a newbie and have not much experience of this! Thanks very much in advance..
      If you go to your epg on any channel check that you have the epg set on the correct mode by pressing the green button
      • bazsutto
        • Apr 2010
        • 10
        #153
        Am I correct in saying the 7-day epg will not pull program synopsis (except for freeview channels) past now and next?
        • johnjones
          • Jan 2013
          • 9
          #154
          yes thats right, will not show anything apart from now and next even after doing epg update on 7day epg channel
          • zee24
            • 3342
            #155
            if you read previous posts you would have seen this:
            To get the 7 day epg do the following:
            first scan in transponder (manual scan) 11778V 27500 , and look for the channels like '8010' or 'portal video 5', they will both appear blank but will download the epg after left on either channel for a min or so.
            select either channel , then press ok and do an epg update and it will download the 7 day epg for you
            then select the guide and alter the epg as you wish using the coloured buttons
            always select that channel to do the download , when required , as it uses it for its epg information
            • bj1
              • 445
              #156
              Yes you are correct guys
              The blade is capable of downloading the 7 day epg,
              But is not capable of downloading anything more than now and next program information.
              Not brilliant but at least you get 7 day epg.
              • zee24
                • 3342
                #157
                you can get more then now and next press guide and the green button you should get epg for the next day atleast especially on the fta channels and most of the pay ones asian channels most likely now and next
                • bj1
                  • 445
                  #158
                  So you can get program information on channels after now and next ? The 7 day epg is fine,
                  Program information repeats itself after now and next,
                  Thats the problem
                  • johnjones
                    • Jan 2013
                    • 9
                    #159
                    Hi Ramjet
                    When scanning for 11778v 27500 on 28.2E no channels come up (also quality showing poor 23%), when i scan for same freq on 19.2 E portal video 5 comes up. But as i am viewing on 228.2e when i go to portal channel, it simply says no or bad signal, hence no epg working.. Thanks very much for your help....
                    • ramjet
                      • 2995
                      #160
                      Hi Ramjet
                      that is because they removed the tv channels
                      • zee24
                        • 3342
                        #161
                        but the epg still works fine on them channel
                        • johnjones
                          • Jan 2013
                          • 9
                          #162
                          ok
                          so how can i now get the 7 day epg pls?
                          • BigfatPaulie
                            • Dec 2011
                            • 203
                            #163
                            Either download a current channel list from a satellite site, or get one from blade media via MENU/BLADE ONLINE... Then tune to an "7 day epg" chan and leave it there for 5 mins or more... If you bring up the channel list you will see it happening!
                            Sent using Tapatalk
                            • ramjet
                              • 2995
                              #164
                              there are still radio channels on that transponder and I believe the epg signals are on those too
