Blade Media 7000s patched firmware 05/01/2012 81x
  • smoggie
    • 863
    #76
    the firmware from the blade website is the unpatched version with no hidden menu, u need the patched version as per this thread
    • markdarlo
      • 6
      #77
      ok thanks for your help. will try it and let u know if its working cheers
      • Nav2010
        • 103
        #78
        Originally posted by zee24
        u shud factory reset with every new firmware anyway.
        factory reset the box, then put the new firmware on, then factory reset again to lock the firmware, then put ur line in and u shud be good to go.
        Yh I did all that for the firmware but I had to keep doin a factory reset for my lines to connect everytime I turned the box off. My m8 put the older version back on for me and it wrks fine now
        • joetwizzy
          • May 2011
          • 322
          #79
          wonder what this "cool feature" they will be releasing "very soon" will be?
          • smoggie
            • 863
            #80
            so how did it go??
            • whitetiger-1234
              my box keep sticking want to try firmware update blade media
              • smoggie
                • 863
                #82
                probably will be another 3 years before we hear from him
                • snakey3796
                  • Sep 2011
                  #83
                  hi guys, how do i enter the hidden cline menu? 9991 doesnt work cheers
                  Hi guys - Ive got the same problem - cant access 9991 - (its my 1st sat box - bought fully clined but cant get hold of my supplier) its got 2010 software on which I want to update, but I believe I need to make a note of the cline details before I upgrade the software or they will be lost ?.
                  Any advice - thanx
                  • rupeshbmnoob
                    • Dec 2011
                    • 36
                    #84
                    Your guess is as good as mine. A few posts back, it was suggested that this new feature could be access to a server where you could stream movies from (or something along the lines of that). However, given the highly questionable legality of such a service (especially at this point in time), I doubt this is what the "cool feature" will be.
                    Perhaps it will be something similar in nature to when the 7 day epg was introduced.
                    • squaredude798
                      • Feb 2012
                      Any advice - thanx
                      If it has cline info on it,then you should be able to access the 9991 menu.On what screen are you inputting 9991?
                      • rick19011
                        • 58
                        #86
                        Is it possible to stream a sopcast stream or another live stream to the blade bm7000s to view the stream on your tv?
                        I also noticed some youtube videos don't work if you select the wrong video resolution.
                        • rupeshbmnoob
                          • Dec 2011
                          • 36
                          #87
                          As far as I'm aware, the only streaming to the Blade that you can do is limited to avi (?) using Blade Stream. You can't stream Sopcast content on to the Blade.
                          However, if you have a PS3 (or an Xbox) you may want to research streaming Sopcast on to that using PS3MediaServer (or something like that). It may work but it may not.
                          • joetwizzy
                            • May 2011
                            • 322
                            #88
                            avi is only a container format.
                            • snakey3796
                              • Sep 2011
                              #89
                              I have now accessed the 9991 menu but cant get details of my cline - its showing connections 0 and 1 connected but when I click on them, it asks for a password which I dont have (and my suppliers telephone number is no longer in use) - Ive tried 0000, 9991, 1234, 9999, etc, but no luck.
                              • rick19011
                                • 58
                                #90
                                I download the 7day epg but it doesn't save to my mp3 plugged into usb port.... what do I need to do because it's annoying when I turn off or put the box in standby the EPG keeps disappearing
