Blade Media 7000s patched firmware 05/01/2012 81x
  • zee24
    • 3342
    #31
    Originally posted by ramjet
    to get 7 day epg on 28e do the following :-
    first scan in transponder 11778V 27500 , and look for the channels like 8010 or portal video 5 that have sly trailers and info
    select that channel , then press ok and do an epg update and it will download the 7 day epg for you
    then select the guide and alter the epg as you wish using the coloured buttons
    always select that channel to do the download , when required , as it uses it for its epg information
    can you select either channel 8010 or prtal video 5 or just 1 of em?
    • ramjet
      • 2995
      #32
      use any you like , just pick one and use it
      I use portal channel 5
      • vorlon2257
        • Sep 2011
        • 356
        #33
        I found out what was causing the insufficient Transponder Memory Error today on my Blade, it wasn't this latest Patched firmware, it was the Channel List that I was using, for some reason it had become corrupted.
        So did a factory reset, loaded the latest Patched firmware went into satellite search, done a full scan of 28.2e, saved channels to flash drive, sorted them into order that I wanted and loaded them back to box again and checked to make sure that everything was working as it should which is was.
        • sakiblateef
          • 311
          #34
          Does this receiver allow you to save the 7 days epg on a hard drive or usb stick?
          I noticed the TM5402 does not have this option.
          • zee24
            • 3342
            #35
            ive lost my 7 day epg channel ive checked evey group and in all channels list its not there, is there anyway i can get it back without doin a total channel re-scan? like a manual dish scan?
            and how do u save your current channel list to my usb?
            • ramjet
              • 2995
              #36
              just download it again on the portal channel as I have said before in this thread
              I save the portal channels into my favourites for easy access , and have them at the bottom of the fav list
              use the download option in the menu to save your cndf to usb stick formatted in fat32
              • zee24
                • 3342
                #37
                i did an epg update on the video portal 5 channel but it still doesnt show me a 7 day epg and in some of the catagories the channels don't show whats on until i choose a channel
                • irishbluestaffy
                  • 611
                  #38
                  same as above
                  • ramjet
                    • 2995
                    #39
                    works ok for me using my own list
                    I did find I had to turn the box off after the new patch was loaded , by switching off at the mains supply for a few minutes before I could get the epg update to work properly
                    and I also mentioned in this thread that you should do the factory resets to ensure a good patch is locked into the box , especially if you encounter problems
                    but some people are lazy and just update the current patch without the factory resets , and then complain when it doesnt work properly
                    having just checked mine again I can confirm a 7 day epg on over 95% of my channels in my favourite groups using 28e only
                    I will also point out yet again that I am not using the lists from their site , but my own bespoke list for 28e only
                    • leon632
                      • 129
                      #40
                      Could you post your cdf?
                      • ramjet
                        • 2995
                        #41
                        with pleasure
                        28e channel list dated 12jan2012 attached
                        use at your own risk , but I use it and my lad also uses it just fine on a bm7000s (non-combo)
                        it is set mainly for north west uk
                        • zee24
                          • 3342
                          #42
                          What i realised when i scan and save the 8010 n Video Portal 5 channel:
                          1. You automatically lose the 7 day EPG channel
                          2. After going to 1 of the channels and doing an EPG update some of the channels still wouldn't show a 7 day EPG so what i did was leave it on the channel for a few mins like you did with the 7 day epg channel, then i found the channels that wern't showing the 7 day epg were doing so now.
                          However after 30 mins i lost the epg again for all the channels so had to do another epg update and in the past couple of hours i have done this 3 times.
                          I have switched it off at the mains as ramjet sugested to get the epg to work better but it made no difference and this firmware is locked as when i downloaded it i did 2 resets as you recommended. Although im not using your channel list i cnt see what difference it would make to my situation regarding this problem.
                          THis may not happen to everyone tho and these 2 channels do update the epg as ramjet has said but for some reason i keep losing the epg after some mins.
                          • mikalos
                            • May 2011
                            thaks for this. Just wish the woukd include the ability to link to a nas
                            • vorlon2257
                              • Sep 2011
                              • 356
                              #44
                              7 day EPG guide working for me, now if they would include NTFS support in the next release, if possible
                              • dragonz
                                • Feb 2010
                                #45
                                fantastic
                                was waiting for the previous patched version...this now supersuedes that...fantastic..
