cloud ibox 2
hi, did you use a miniature soldering iron as it does seem fiddly
ThanksComment
Hi, is this the right one ?
100 x 0 Ohm SMD/SMT 0805 Resistors / Link (0R) - UK - 1st Class Post | eBay
ThanksComment
That will work.Hi, is this the right one ?
ThanksComment
Would it be possible to snip the said resisistor in the middle to break the flow then solder the new resistor on top of the old one.Comment
Got mine a fee days ago. Looks good image pre-in-installed. I have a major tuner problem. The tunrr st bavk of box is loose and is not picking up any channels. Tried my solo2 with the same wiring with the same LNB. All channels where fine. So the tuner is very slack and wont pick up anything. Opened the box & the tuner looked very open and unstable. I will try & post some pics. Could someone please post a pic of there tuner from inside the box. I think there's a bit missing from the inside of the tuner. Anybody with similar problems would be a great help. Thanks Eddie
Sent from my GT-I9300 using TapatalkComment
Hi, look you have the broken connector antennaGot mine a fee days ago. Looks good image pre-in-installed. I have a major tuner problem. The tunrr st bavk of box is loose and is not picking up any channels. Tried my solo2 with the same wiring with the same LNB. All channels where fine. So the tuner is very slack and wont pick up anything. Opened the box & the tuner looked very open and unstable. I will try & post some pics. Could someone please post a pic of there tuner from inside the box. I think there's a bit missing from the inside of the tuner. Anybody with similar problems would be a great help. Thanks Eddie
Broken connector antenna.jpgComment
