cloud ibox 2
  • jenseneverest12
    • Nov 2013
    • 22
    #601
    100x SMD/SMT 0805 Resistor 0-1k Ohm Range | eBay
    you want the 0R 0ohm resister.
    • lincsat
      • 1228
      #602
      Or if you have a RS store nearby -
      http://uk.rs-online.com/web/p/products/679-0800/?origin=PSF_433010|QVTNS-LL
      • lombard
        • Aug 2008
        • 793
        #603
        Originally posted by jenseneverest12
        hi, did you use a miniature soldering iron as it does seem fiddly
        • jenseneverest12
          • Nov 2013
          • 22
          #604
          You need a very fine tip solder iron, a magnifying glass, solder wire, flux and a pair of tweezers. Oh and a cold beer to calm the nerves....
          • lombard
            • Aug 2008
            • 793
            #605
            my luck item ended
            • lombard
              • Aug 2008
              • 793
              #606
              Hi, is this the right one ?
              100 x 0 Ohm SMD/SMT 0805 Resistors / Link (0R) - UK - 1st Class Post | eBay
              • jenseneverest12
                • Nov 2013
                • 22
                #607
                That will work.
                • bighun
                  • Nov 2010
                  • 151
                  #608
                  out of the boxes you have fixed jenseneverest12 are they all still working ok
                  • orientville
                    • 66
                    #609
                    Would it be possible to snip the said resisistor in the middle to break the flow then solder the new resistor on top of the old one.
                    • bighun
                      • Nov 2010
                      • 151
                      #610
                      it looks like they are just soldered at each end all you need to do is heat one end and hold it with small pliers and it will lift of then do the same with the other side if your eyes are like mine you will need a magnifying glass
                      • pl1976
                        • Feb 2010
                        • 213
                        #611
                        cloud ibox 2
                        Anybody get this today?
                        • bighun
                          • Nov 2010
                          • 151
                          #612
                          yes i got this to about 2 hours ago
                          • morph8000
                            • Apr 2013
                            anybody tested this firmware?
                            • eddhutch
                              • Sep 2013
                              • 13
                              #614
                              Got mine a fee days ago. Looks good image pre-in-installed. I have a major tuner problem. The tunrr st bavk of box is loose and is not picking up any channels. Tried my solo2 with the same wiring with the same LNB. All channels where fine. So the tuner is very slack and wont pick up anything. Opened the box & the tuner looked very open and unstable. I will try & post some pics. Could someone please post a pic of there tuner from inside the box. I think there's a bit missing from the inside of the tuner. Anybody with similar problems would be a great help. Thanks Eddie
                              Sent from my GT-I9300 using Tapatalk
                              • dimonk
                                • Dec 2013
                                Hi, look you have the broken connector antenna
