create a bootlog if you want to be sure what ram, cpu and memory it has. and no it's nothing to do with the images but the drivers and considering the original has a inbuilt security board they must be patching the drivers or using another method to get around that.
Hi thats true, but its like ?65 - ?70 , runs enigma 2, openpli 4 , runs quite well, would say it runs better then vu solo and much better then dm800hd, also heat wise its great, hardly any warmth
There is no openvix 4.0 ( not in the public domain any way ) so if there giving you a openvix 4.0 image be very careful as god only knows what that contains, plus the original openvix 4.xx series images are buggy as hell, hence why we have not released them.
Ok all set up on vix the only problem is when i have recorded there is no movie player in menu and no button on the remote like vu+ rmotes to access recordings. Anyone got a solution. Apart from that running good on vix
