hi! went to plugins picons, went down to tv--ocram.hd.transparent-white (2013-11-17) downloaded, installed. went to menue - settings -system- user interface - and switched on 'show picons in channel list'. When i tried downloading another ocram package to flash, box crashed!
Gesendet von meinem JY-G3 mit Tapatalk
if you already had picons , you have to delete them, and then try again
unstalled first ocram package, installed another, and picons showed up again without problems.
thanks, might be my tv then, i tried all the av settings, 720p , 1080i and 1080p all same, also when you select a channel, doesn the info bar be blurry for second then sort itself out ? its strange as soon i turn off picons in channel list, then when in channel list its fine, really like oscram picons in channel list , look very good, so hope can find out reason
Try unplugging the card reader, then reflash. Had the issue on another type of box, but worth a try.......
Had it open firstly no card reader :-(
Secondly no heatsink !!!! I'm off to a PC Shop tomorrow to see if I can get a little heatsink and paste then will try that. But none of mine have either heatsinks or Card readers.
Wow, well shoody is not the right word, beep beep beep
That will be the issue, i doubt the card reader will be required.....the cpu is overheating.
Guess the factory ran out in its hurry to ship out.......let us know how you get on!!
You may have to bridge some pins with the reader removed.....pm me
Reason: mistake
I added two more pictures from inside ibox 2. Picture one shows cardreader with smartcard. I had to loose 4 screws, to be able to move cardreader and insert card. Unfortunately nor cardreader, nor smartcard did show up in cccam. Seems as cardreader is not integrated in hardware correctly. Or can this be solved? Any proposals would be very recommended.
Second picture shows front view towards inside cardreader. Outside card slot does not fit to the position of cardreader. If you want to put your smartcard into smartcard reader from the outside box, you must cut additional slots into plastic
your card reader looks like it's upside down, turn it round the other way
I found the method to change the opening image, just upload the file in the folder splash.bin MK1000 then turn on the decoder and use the key-vol. doing so would change the opening image
i received my box from*********
but the card slot reader is missing on my cloud ibox II .... im very lost !!
Reason: removed link
