cloud ibox 2
  • waqsss
    • Oct 2010
    • 15
    #556
    Originally posted by RuberDuck
    Nothing if your using a Vu+ Duo with obvious signs of the infamous memory leak, but for every other receiver it works the opposite, ie it creates instabilities.
    Thanks ill uninstall it. I also have a vu+ duo which has it running.
    • freck
      • 1076
      #557
      Getting back to the issue of the box just stopping. ...will a replacement psu do the trick.
      Im gonna try the psu from the mk1000 original box and see how it behaves.
      P.s
      Just noticed that the mk1000 uses a 2.5amp psu.....clone use a 3amp
      Sent from my GT-I9300 using Tapatalk
      • jenseneverest12
        • Nov 2013
        • 22
        #558
        Please keep as informed as to where that works or not...i have the issue too
        P.s
        • lombard
          • Aug 2008
          • 793
          #559
          Hi, just managed to get hold of a 2amp PSU and will test now, also running latest vix 3.0 ,
          i notice vu solo runs much smoother on vix 3.0 then ibox 2 , navigating is quicker
          • freck
            • 1076
            #560
            Tried it on the other psu and it makes no difference.
            Its pack up faster if you navigate tru the menus.
            • jenseneverest12
              • Nov 2013
              • 22
              #561
              I havn't had an issue with vix, i use the vix crossepg as its made for the image.....
              • lombard
                • Aug 2008
                • 793
                #562
                i had time with both the vu solo clone and the ibox 2 both running vix 3.0 and can tell the solo runs smoother, and its more responsive,
                the blanking out i was getting randomly don't think it was image issue, mines has heatsink on cpu and its barely warm so i know its not heat issue, got 2amp psu now will soon find out
                • bighun
                  • Nov 2010
                  • 151
                  #563
                  i am running mine with my cloud ibox power supply never had a problem
                  • lombard
                    • Aug 2008
                    • 793
                    #564
                    Hi, ok same thing happened with the 2amp PSU so can rule out using 3amp psu was problem , most likely box is faulty, guess that's what you get with clones, anyone find out what fault this is caused by ?
                    • jenseneverest12
                      • Nov 2013
                      • 22
                      #565
                      Thanks for that, mines comming to bits now i know its not psu, most likely the cpu will require a reflow, the first boxes didn't have a good heat sink( or any in some case's).....as you said clone, made in china.... i have had this on the solo clone as well.
                      Also i have had a nand issue on an alien2 and cpu on a xpeedlx2 so i would say its a normal issue for a sat box. They all use bits made in China by the lowest bidder. Only differance is when you buy from china there is no easy return like a genuine box. Its a gamble simple as that.
                      • ajax2061
                        • Nov 2012
                        • 395
                        #566
                        mine cleared customs today hoping to get monday/tuesday excited to get to play with a e2 box after the f3 ive had for a year now (will still be using as its easy for the mrs to use) cant wait too sink me teeth into it , as for the psu wouldn't a higher ampage psu be better than a lower one ? surly the unit only going to draw what it needs ? Let us all know if the reflow works as got a nice hot air solder station at work for this kinda stuff.
                        • waqsss
                          • Oct 2010
                          • 15
                          #567
                          No heat sink in your one?
                          I opened mine and its got similar heat sink to the one in the vu+ duo. Just some black metal thing.
                          What plugin can I install to monitor CPU temp?
                          • RuberDuck
                            • 1724
                            #568
                            nothing as it does not have the hardware required to monitor temperature.
                            • rpatel2
                              • 8
                              #569
                              i've tried a 1amp psu but no luck in resolving the black screen issues
                              • lincsat
                                • 1228
                                #570
                                According to Airsat, the first batch had a DDR problem, they offered to send some chips when I ordered the new "fixed" boxes. The new ones have a card reader and a nut holding the F Socket to the case.
