i already try to this method but the message " Set stb error.Click 'back' to try again." i think my box is already dead as it can be..
Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
my skybox M3 is stuck on L100 on the display & no picture on the tv I have a null modem cable any ideas how I bring it back to life?
Tried Upgrade pvr800 hd tool with captains bigger log.abs but get SET STB Memory Error when trying to flash?Last edited by beats2006; 20 September, 2012, 13:48.Comment
Ok I was having the same problem and just fixed it finally after a lot of trial and error heres what I did -I've a new skybox m3 died (only red light when powered and no remote controls' effects...)
Tryng to refresh firmware by rs232 null and erom upgrade 2.0.0c 2009-05-22...
FW: SKYBOX_F3_M3_wifi_3601HD_CMT_1209040733.abs
Set stb memory error
I think COM1 settings are ok... I've tried several possibilities...
Can I try something else or sendig back the box to the seller is better ?
Thanks, byes,
Ezio
downloaded http://www.digital-kaos.co.uk/forums...de_8mflash.rar
then downloaded some older firmware -
SKYBOX_3601hd_CMT_120820071a.abs
(if you search google you will find it)
Then I plugged the box in and attached the null modem cable,
opened up the erom upgrade folder and ran CONFIG.BAT
then ran EROMUPGRADE
Selected the firmware I downloded
Ticked Include Bootloader
Clicked next
when it says-
synchonizing stb
Reset target
I unplug and replug the power cable out of the back of the box quite fast it will then let you carry on and recover the box
once recovered you can update to a later firware via usb or the X3 Lan tool.
hope this works for you as I was pulling my Hair out yesterdayComment
I'm going to buy an RS232 to USB cable off eBay so I can use it on my laptop and I was wondering if this would work on a S11
USB to Serial DB9 Pin RS232 DB25 Parallel Printer Cable GPS PDA 1M 1.2M 1.5M 2M | eBayComment
