Recover Dead Skybox/Openbox Flash Using Serial RS232 Null modem Cable
hi
im following the steps in the instructions and when i click run for the eromupgrade.exe it just keeps telling me wrong file
its for a skybox f3
many thanksComment
This can happen if it doesn't recognise the file you select in the browse window.
Are you selecting a .abs file for your model of box?Comment
Hi folks, anyone help with this post above from earlier in the week??Hi all, I have read through this thread thoroughly (yep all 39 pages) to look for answer to resolving dead F5s. The problem im having is box is showing figure '8' with faint red light, have tried to go through all the different links to Erom upgrade for F3/F5/F5s which all have the same Erom Upgrade tool - STB EROM Upgrade 2.0.0c. After I go onto browse file put in a .abs file (I have tried many different ones) and press next it comes up with 'Synchronizing STBs.. Please reset target!' . At this point I have tried many methods of powering up box, putting plug in/putting power cable in and connecting at different times i.e. 2 secs, 4 secs, 7 secs but unfortunately it just wont connect. I have just reflashed a openbox S11 and have previously done a few before with no problems. So why cant I get this Skybox F5s to sync with Erom? Any advice giving greatly appreciated.Comment
I have experienced a couple of boxes like yours, where the box isn't even recognised at switch on & have come to the conclusion that there is more wrong with the box than just a simple reflash.
Like any kind of electronic equipment, failures do happen. The fact that you have flashed other boxes rules out any "finger trouble".Comment
Dude thanks you save my box, after two days going crazy wit the damm Set stb memory error. RegardsOk I was having the same problem and just fixed it finally after a lot of trial and error heres what I did -
downloaded http://www.digital-kaos.co.uk/forums...de_8mflash.rar
then downloaded some older firmware -
SKYBOX_3601hd_CMT_120820071a.abs
(if you search google you will find it)
Then I plugged the box in and attached the null modem cable,
opened up the erom upgrade folder and ran CONFIG.BAT
then ran EROMUPGRADE
Selected the firmware I downloded
Ticked Include Bootloader
Clicked next
when it says-
synchonizing stb
Reset target
I unplug and replug the power cable out of the back of the box quite fast it will then let you carry on and recover the box
once recovered you can update to a later firware via usb or the X3 Lan tool.
hope this works for you as I was pulling my Hair out yesterdayComment
sitting at home watching tv when my s10 just went blank
tied the usual power fuse etc all ok but when I took out the
cable from my dish at the back of box it was red hot and on
checking cable t was wet so water getting in to my cable as
it runs down front of house as the cables upstairs thru the
attic are ok so just wondering anyone ever have this happen
if yes was box fixableComment
Will this work on a Skybox A3
The box are supposed to be a legit one.
The box just reboots after it counted to 100.
Not sure why this happend but i had just sent back TPROG.dbs file to the box.
Edit problem resolved
found a program with correct bootloader.
