Dreambox streaming to internet,it was never easy like this
  • mfaraj57
    • 557
    #91
    from the test
    just for test i stopped streaming then i start it from my side
    Sure there is error in port 1234
    did you see video in restreaming window
    did you try to open other port let,s say 1235
    dns address is ok
    • Dedes
      • 19
      #92
      Originally posted by mfaraj57
      from the test
      dns address is ok
      Yes I see video on the restreaming window and I have tried port 1235 but with no luck.
      Do you think problem can be somewhere else like on the Dreambox? I am using a DM500.
      Do you sugest a diferent port besides 1235?
      • mfaraj57
        • 557
        #93
        before using any port you have open and forward it
        check the port is opened or not by this
        • Dedes
          • 19
          #94
          PortForward.com - Free Help Setting up Your Router or Firewall
          With the Streamer closed it says that port 1234 is open both UDP and TCP but with the streamer open it says that a software is blocking this port
          • mfaraj57
            • 557
            #95
            Everything is ok
            port 1234 is opened
            dns address is ok
            try to put firewall off and try
            • mfaraj57
              • 557
              #96
              you said vlc version .9
              you mean .99 or .9
              please select radio channel and start streaming on port 1234
              from settings choose low internet speed
              what image installed in your dreambox
              • Dedes
                • 19
                #97
                you mean .99 or .9
                vlc version is the one you have put here to download and the image I have on my dream is gemini
                • Dedes
                  • 19
                  #98
                  Done
                  I have put the software working but after all this work because I have a DM500 with Gemini as an image pictures are very very poor.
                  Maybe something will come up to solve this problem
                  • mfaraj57
                    • 557
                    #99
                    For good streaming pli-jade image should be installed
                    i think now your problem from gemini
                    pli-jade is good image
                    pli-jade dm500
                    • mfaraj57
                      • 557
                      #100
                      The installed image on dm500 and enigma1 dreamboxes in general plays a role in streaming and recording
                      we found the best image to do these things well is pli-jad and the worst is gemini image
                      pictures from archive of my work team who tests the images
                      • .: JaCkPoT :.
                        Retired Sat TV Addict
                        • Aug 2008
                        • 5611
                        #101
                        Lol look at the difference!
                        ___________________
                        In the good old days, I had
                        DM800s HD
                        Openbox S10
                        TM500
                        DM500s
                        90cm FortecStar dish
                        Maxx 110cm Dish
                        Technomate 2300 Motors
                        • mfaraj57
                          • 557
                          #102
                          Live stream from dreambox radio channel radio3 on hotbird-best seen by microsoft internet explorer
                          • ireland-batt
                            • 63
                            #103
                            great program took a bit of learning about port forwarding and adding dyndns to router but tbh taught me stuff i should know .
                            working on vista ult and prem and streaming great on darkstar II 7020 even on wireless
                            tho get message dreambox webinterface plugin is less than 1.5 please update to recent version ? think this is causing it to crash the odd time ?
                            technomate 5400ci+ fortec star 90cm dish and motor
                            darkman patch
                            dreambox 500c dk1.1
                            dreambox7020s img tbc
                            dbox2 sagem 2x
                            commando 8.2
                            • dowlinr
                              • 226
                              #104
                              I had troubles with this on my laptop. I loaded it on my pc and it works but there are a few bugs (which I can live with).
                              When I change the channel on my dreambox it reconnects to the stream but loses sound. I have to restart the app before sound works again.
                              Another issue I have is my bouquets start with Astra 28.2e which is empty, then I have UK tv which starts with bbc1, bbc2 etc. The app seems to have added a random bouquet called 2AE which now has all the channels that should be in UKTV. UKTV now has sky movies channels, sky sports are now in my movies bouquet etc.
                              This bouquet issue also happened in Dreambox viewer ver 4.0
                              In all I am very impressed with the app, very good work Mfaraj
                              • mfaraj57
                                • 557
                                #105
                                Thanks Ireland-batt
                                As you said streaming by the program is very easy and direct just choose channel and start streaming
                                The problem is always in port forwarding and creating dns address and these are not undercontrol of the program
                                Regarding the message ,this should appear only with enigma2 dreamboxes because program will not interact with enigma2 webinterface version less than 2.5,however thanks for your note and i will see why this occurs
