SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • markshore
    • Oct 2010
    • 120
    #601
    Originally posted by gspeedy
    Am using EDG Nemesis 2.2 image on DM800HD and when i load latest Bouquet here.
    All i get is greyed out channel list that dont work.
    List looks well good. Anyone know how i can fix this?
    Thanks flipflop
    Hi had the same as you were getting after flashing a new image Nemesis 2.2 bouquet greyed out although scanned channels ok and can be viewed, was down to my tuner setup.
    Regards
    Mark
    • irsh12
      • Oct 2010
      • 108
      #602
      Regards
      Mark
      How did you fix this please, I'm having the same problem.
      Thanks.
      • lincsat
        • 1228
        #603
        As I posted a few posts ago - check your Antenna/Tuner configuration. The boxes grey out channels on Sats that are not configured.
        • irsh12
          • Oct 2010
          • 108
          #604
          Thanks I've managed to do it.
          • irsh12
            • Oct 2010
            • 108
            #605
            How do I add the picons into my dreambox?
            Thanks.
            • raz0r19
              • Nov 2010
              • 9
              #606
              Irsh ...follow this directions............ http://www.digital-kaos.co.uk/forums...ml#post1107938
              • mit2007
                • 162
                #607
                Thanks to SGTFlipFlop for your great hardwork. These bouquets work but some channels are blank. with error
                • irsh12
                  • Oct 2010
                  • 108
                  #608
                  Thanks, it helped me alot.
                  • funkyphantomxx
                    • Jun 2011
                    #609
                    can anybody help iv just bought the 800 and had it flashed messing a round with moving the bouquets
                    a round and sports has disappeared how do you get them back they were not deleted
                    • blondsta
                      #610
                      Originally posted by SGTFlipFlop
                      Here is the latest update
                      DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
                      Enigma 1 = Dreambox 500, 600, 7025
                      Enigma 2 = Dreambox 800, 8000, 500 HD
                      Updates: 22nd May 2011
                      Bouquet Updates
                      15.8e - Tring Package Updated
                      19.2e - Few Channel Changes
                      13e - Few Channel Changes
                      Removed Channels
                      Gala TV
                      Picons
                      Updated Few Old Picons to New Ones
                      I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
                      ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                      Also added Picons for Sky UK,
                      All correctly mapped and a few obscure ones missing only
                      Use any FTP client, DCC for example, to transfer the picon directory to
                      one of the following paths on Flash, HDD, CF or USB respectively:
                      /usr/share/enigma2
                      NOT recommended, because of limited capacity of the flash memory
                      /media/hdd
                      HDD will keep running indefinitely and may affect image performance
                      /media/cf
                      Recommended if CF available and successfully mounted (8000/800)
                      /media/usb
                      Recommended if USB available and successfully mounted (8000/800)
                      Picon will display immediately on zapping, no further setup required!
                      Always remove old picons from Dreambox before uploading new ones,
                      Sometimes they don't overwrite correctly
                      Please keep this thread clean, Use the Thanks button rather than posting on the thread
                      Hi, I'm probably being a noob but, when trying to download the bouquets, I keep getting a .torrent file, which i try to open with utorrent and get invalid file. Any help would be appreciated.
                      • SGTFlipFlop
                        • Sep 2009
                        • 1002
                        #611
                        DreamboxEdit 4.1.0.0 Used (Recommended) Guide Here
                        Updates: 6th June 2011
                        Bouquet Updates
                        BBC HD (New Frequency)
                        BBC One HD (New Frequency)
                        ITV 3D (New Channel - Testing EPG)
                        Daystar (New Frequency)
                        SonLife Broadcasting Network (New Channel)
                        Removed Channels
                        Daystar
                        Picons
                        Updated Channel Changes
                        /usr/share/enigma2
                        /media/hdd
                        /media/cf
                        /media/usb
                        • tosh2004
                          • 100
                          #612
                          Hi, when i upload them into my box all channels become gray????
                          • tosh2004
                            • 100
                            #613
                            thank you guys just sort it out my self
                            • ciamarx
                              • Jun 2011
                              #614
                              I have just loaded these bouquets to my DM500, at first I kept getting a message: Swtich: service can not be found. Now it just crashes when it trys to load a channel.
                              Anyone got any ideas? I am using the Nabilosat II image. All the channels worked fine before this was loaded.
                              • mit2007
                                • 162
                                #615
                                mate you are doing something wrong. use a another web browser or uninstall and reinstall the same web browser. then try downloading. or check the settings (web browser) of how it opens downloaded files it maybe set as torrent default.
                                i hope it helps you.
                                Regards,
                                mit2007
