SGTFlipFlop SKYUK Bouquets - Updated Regularly
Irsh ...follow this directions............ http://www.digital-kaos.co.uk/forums...ml#post1107938Comment
Thanks, it helped me alot.Irsh ...follow this directions............ http://www.digital-kaos.co.uk/forums...ml#post1107938Comment
can anybody help iv just bought the 800 and had it flashed messing a round with moving the bouquets
a round and sports has disappeared how do you get them back they were not deletedComment
Hi, I'm probably being a noob but, when trying to download the bouquets, I keep getting a .torrent file, which i try to open with utorrent and get invalid file. Any help would be appreciated.Here is the latest update
DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7025
Enigma 2 = Dreambox 800, 8000, 500 HD
Updates: 22nd May 2011
Bouquet Updates
15.8e - Tring Package Updated
19.2e - Few Channel Changes
13e - Few Channel Changes
Removed Channels
Gala TV
Picons
Updated Few Old Picons to New Ones
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Code:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Please keep this thread clean, Use the Thanks button rather than posting on the threadComment
DreamboxEdit 4.1.0.0 Used (Recommended) Guide Here
Updates: 6th June 2011
Bouquet Updates
BBC HD (New Frequency)
BBC One HD (New Frequency)
ITV 3D (New Channel - Testing EPG)
Daystar (New Frequency)
SonLife Broadcasting Network (New Channel)
Removed Channels
Daystar
Picons
Updated Channel Changes
Please keep this thread clean, Use the Thanks button rather than posting on the threadLast edited by satsmo; 25 August, 2011, 22:08.
I have just loaded these bouquets to my DM500, at first I kept getting a message: Swtich: service can not be found. Now it just crashes when it trys to load a channel.
Anyone got any ideas? I am using the Nabilosat II image. All the channels worked fine before this was loaded.Comment
mate you are doing something wrong. use a another web browser or uninstall and reinstall the same web browser. then try downloading. or check the settings (web browser) of how it opens downloaded files it maybe set as torrent default.
i hope it helps you.
Regards,
mit2007Comment
