Cloud ibox unbranded solo clone
  • moskolio
    • 7
    #286
    Originally posted by kkkkklaur
    Cloud not have hardware fan control .....
    you have this option
    1. Put the OLD gsm phone charger 5v to move the fan and the speed is slow
    2.Use the function --deep standby--- (image OPEN AAF) to stop total the cloud with remote...
    3.use the fan with automatic speed control with heating (with NTC sensor inside)
    thank you for your answer
    i am sorry but i can not understand what you mean on number 1 and number 3.
    can you please try to explain them a bit better
    1. what is an old gsm phone charger?
    3. Do you have a picture or a guide of this setup?
    • billalahmed
      • May 2010
      • 15
      #287
      any1 got a safe vix image which i can install on my cloud ibox, I tried installing vix 3.0.743 but get blank screen. Also whats the best image out there to use?
      • MENTE SICULA
        • Sep 2013
        • 18
        #288
        try this:
        OpenPLi-4.0-beta-vusolo-20130902
        • lombard
          • Aug 2008
          • 793
          #289
          you need build 721 or lower
          • billalahmed
            • May 2010
            • 15
            #290
            I cannot seem to get picons to load up correctly, they seem to be in the wrong order, also out the 643 picons only 57 get transferred to my usb. any help?
            All sorted, turned out my usb was playing up so tried another usb.
            • kkkkklaur
              • Sep 2013
              • 9
              #291
              Cloud ibox best and stable image download link (FREE download in regular mode)
              http://dfiles.eu/files/qevo1ql8l
              THE NEW IMAGE (all team image) after ( in general 15-08-2013) use protection by chip v3.2 version and is need upgrade software security chip v3 to version v3.2 (only for v3 chip) for work with new image software.
              v1,v2 security chip need hardware upgrade.
              • kkkkklaur
                • Sep 2013
                • 9
                #292
                Used to power the fan clone old phone charger (5v) so not push the limit source is sized and powered fan with two separate wires sticking them through the slot left free box fan will go slow and you will not make noise more and eating less ef cooler can let go non stop.
                • calcu
                  • Nov 2011
                  • 4
                  #293
                  My 2 cents.
                  Installed every image i can imagine..., now BH 2.0.5 updated to version b with Cccam is working perfectly.
                  This box just have only one problem....
                  When you reboot it, sometimes (i don't know when or why), it just outputs a blank screen, but you can see the network leds working fine and the blue light (the remote one), working fine too.
                  i think it's something about power.
                  If you have an usb fan or usb stick attached, it only boots up 1 time of 10.
                  if you don't have anything connected it will boot, but, if it doesn't boot, just switch the unit off, wait a moment a turn it on, in 3 or 4 times it will boot.
                  when it doesn't boot, i could see this log with putty:
                  setenv('prefix', '/usr', 0)
                  setenv('exec_prefix', '/usr', 0)
                  setenv('bindir', '/usr/bin', 0)
                  setenv('sbindir', '/usr/sbin', 0)
                  setenv('libexecdir', '/usr/libexec', 0)
                  setenv('datarootdir', '${prefix}/share', 0)
                  setenv('datadir', '/usr/share', 0)
                  setenv('sysconfdir', '/etc', 0)
                  setenv('sharedstatedir', '/com', 0)
                  setenv('localstatedir', '/var', 0)
                  setenv('libdir', '/usr/lib', 0)
                  setenv('localedir', '${datarootdir}/locale', 0)
                  setenv('prefix', '/usr', 1)
                  setenv('exec_prefix', '/usr', 1)
                  setenv('bindir', '/usr/bin', 1)
                  setenv('sbindir', '/usr/sbin', 1)
                  setenv('libexecdir', '/usr/libexec', 1)
                  setenv('datarootdir', '/usr/share', 1)
                  setenv('datadir', '/usr/share', 1)
                  setenv('sysconfdir', '/etc', 1)
                  setenv('sharedstatedir', '/com', 1)
                  setenv('localstatedir', '/var', 1)
                  setenv('libdir', '/usr/lib', 1)
                  setenv('localedir', '/usr/share/locale', 1)
                  resolve: resolve ${datadir}/enigma2/encoding.conf
                  resolve: -> /usr/share/enigma2/encoding.conf
                  resolve: resolve ${libdir}/enigma2/python
                  resolve: -> /usr/lib/enigma2/python
                  PYTHONPATH: /usr/lib/enigma2/python
                  + (1) Background File Eraser
                  + (8) graphics acceleration manager
                  /dev/fb0: No such file or directory
                  + (9) GFBDC
                  framebuffer not available.
                  FATAL: no framebuffer available
                  resolve: resolve ${sysconfdir}/enigma2/settings
                  resolve: -> /etc/enigma2/settings
                  resolve: resolve ${libdir}/enigma2/python/
                  resolve: -> /usr/lib/enigma2/python/
                  Segmentation fault
                  thinking that normally it works fine... i believe that some capacitator is small or something like that, but... i don't have any idea about which can be .
                  Despite of this.. i'm happy with this box xD
                  • lombard
                    • Aug 2008
                    • 793
                    #294
                    i had about 4 of these, and loaded in openpli 3.0 and not had any issues, image loaded to get full 7 day epg, etc , had them running for 2-3 weeks no crashes or problems at all , i found vix 3.0 would last a day or 2 before crashing
                    • orientville
                      • 66
                      #295
                      New updated version of this box hits the market 600mhz bigger quieter fan 1g flash/1g ram v3 chip anyone tried this box yet.Its called cloud ibox 2
                      • kkkkklaur
                        • Sep 2013
                        • 9
                        #296
                        ATTENTION! update RS232 Cable CABLE IS NOT NULL MODEM cable or RS232 classical.. The dongle is attached to the cable or change the connection pin plugs as prescriptions (VU +) pin failure may damage the STB software
                        • MENTE SICULA
                          • Sep 2013
                          • 18
                          #297
                          this is the real ferrari cable for VU+ Solo/Duo clone and its corresponding interface
                          http://s24.postimg.org/dkkzxt6ap/5894
                          • orientville
                            • 66
                            #298
                            Is this needed for the new ibox2 if using blackhole image.
                            • kkkkklaur
                              • Sep 2013
                              • 9
                              #299
                              This is the pin modification conection for CLOUD IBOX (BCM 7325 chipset) (null-modem cable)to upgrade security chip wihout dongle adapter
                              pin 2,3,5- PC
                              pin 6,4,5- Vu+ (CLOUD IBOX)
                              for use the pack software update search with google and download this...
                              ....security chip update V3.2
                              (Not use another combination of pins for modify null modem cable for security cip upgraded to v3.2 that damage the receiver software.
                              UPGRADE v3 to v3.2 is ONLY! for receiver with v3 security chip inside..
                              For receiver v1 or v2 security chip inside is neeed hardware(not software) upgrade (new upgrade with chip v3.2)
                              For inexperienced people is reccomended to use software images in the first half of August 2013 and let the receiver as is for now.
                              Another 3 alternative is
                              1.DOWNLOAD CLONE VU SOLO Software
                              search in google window ---- np-ulc---- and in first adress link go to:
                              Receiver / Clone Boxen/Images/Clone Vu+ Ferrari/Clone Solo
                              2.search in google window
                              ___Official DE OpenBlackHole BH 1.4____
                              and use image for your security chip inside (in first link open in google have all version for vusolo Ferrari (cloud ibox)
                              2. Search and download latest patch images works for with new security upgrade
                              BlackHole 2.0.6 Ferrari V2/V3 by Toysoft
                              information is only for educational use and Viewing Pay TV without a valid subscription is illegal
                              Last edited by kkkkklaur; 9 October, 2013, 20:41. Reason: Read our rules again please.
                              • calcu
                                • Nov 2011
                                • 4
                                #300
                                this may sound silly but...
                                which side of the cable is attached at the pc and which is at receiver?
