Cloud ibox unbranded solo clone
  • bighun
    • Nov 2010
    • 151
    #346
    you will get autobouquets here http://www.digital-kaos.co.uk/forums...e-plug-296869/ also tspanel here.................................also tsmedia..................................... use vucc and ftp them to the tmp folder then install them using menu addons manually install ipk packages once you install autobouquets press green button press menu go to local area selection put in hd area you are in then press green to install takes a wee while to do but it puts all the channels in the same numbers as sky you will need to register with the forums to download the stuff
    Do not post links to other forums with similar content
    • Pillhead
      • Dec 2010
      • 71
      #347
      thanks i was trying to get rats updaters working for his bouquet and picons like i have on my dm800.
      How ever all the link you just sent me install but auto bouquet just green screens when i try and update any ideas?
      I was going to set up cross epg to my usb stick and picons on there, and i think some one mentioned putting a swap file partition or something on there?
      Be nice to get it all going tonight but im getting tired now
      Also be nice to get IPTV updater working as well but alas that wont install either
      • bighun
        • Nov 2010
        • 151
        #348
        you will get iptv in tsmedia when installing autobouquets have you done a scan for channels if you have press up arrow then yellow select bskyb press ok then try installing autobouquets
        • digicon
          • 8261
          #349
          The TSmedia plugin can be found on this very forum: http://www.digital-kaos.co.uk/forums...plugin-332694/ without having to link to others
          • Pillhead
            • Dec 2010
            • 71
            #350
            IPTV updater is far superior and has a much better selection and adds them to your bouquet. How ever i cant get that to work or Autobouquets....
            For now ive given up and will carry on trying tomorrow
            • Pillhead
              • Dec 2010
              • 71
              #351
              Woke up this morning and box wouldnt turn on. had to un plug it from mains and back in again.
              Hope it was just a one off .
              • bighun
                • Nov 2010
                • 151
                #352
                i leave my box on 24/7 not caused any problems with heat
                • Pillhead
                  • Dec 2010
                  • 71
                  #353
                  well i turned mine upside down and the heatsink was cool to the touch with the factory fan.
                  how ever turned the other way it was scorching, although my dm800 tuner is like that after 5 mins
                  I might try and mod it im not sure yet i just want to find a stable image where the plug ins that i want will run, mainly rats bouquet updater,rats picons updater and IPTV updater. OH and iplayer and itv player which run lovely on my DM800
                  • Pillhead
                    • Dec 2010
                    • 71
                    #354
                    My box seems fine when im using it but i turn it to standby some times it wont restart or when i come back to it it has crashed and needs to be unplugged and back in again before it will work.
                    Also the remote is very sluggish until a few mins after the image has booted?
                    Not sure whats going on as nothing has happened when im actually using the thing.
                    • lombard
                      • Aug 2008
                      • 793
                      #355
                      anyone ordered the ibox 2 yet ? thanks
                      • djrikstar
                        • Nov 2011
                        • 172
                        #356
                        Has anyone had the issue with the box not flashing its just a blue light and no display tried different images but just turns from red when i switch on, then straight to blue and does nothing. I have a m8 who has same issue. Anyone know of a fix or the right software to use on them to flash via serial? As tried many times to do with a usb it as if it doesn't recognize the usb no purple light
                        • digicon
                          • 8261
                          #357
                          Have you tried any different USB sticks just in case the one your using the box does not like
                          • Pillhead
                            • Dec 2010
                            • 71
                            #358
                            Im using a vix image now and its been stable for a few days. when it works its lightening fast! only thing id be happier with is a cool running box and a proper sub forum for cloud ibox with images and plug ins rather than keep trying ones from a vu solo which a lot of dont work.
                            • MENTE SICULA
                              • Sep 2013
                              • 18
                              #359
                              if someone want try... this is the last
                              Vu+ Solo : BlackHole 2.0.7 Ferrari V3 by Toysoft
                              Blue Menu fix, use Ferrari Addon Manager,
                              1) Go to FAM Plugin on BlackHole 2.x.x
                              2) Select Fix
                              TS
                              • lombard
                                • Aug 2008
                                • 793
                                #360
                                the thing is it is a clone of vu solo , the newer updates of images dont work, as vu have updated the drivers to stop working on clones, just stick to slightly older images or get patched , i have had no issues plugins working , if it works on vu solo it will work on these
