you will get autobouquets here http://www.digital-kaos.co.uk/forums...e-plug-296869/ also tspanel here.................................also tsmedia..................................... use vucc and ftp them to the tmp folder then install them using menu addons manually install ipk packages once you install autobouquets press green button press menu go to local area selection put in hd area you are in then press green to install takes a wee while to do but it puts all the channels in the same numbers as sky you will need to register with the forums to download the stuff
Do not post links to other forums with similar content
any ideas?
