Page 14 of 51 FirstFirst ... 491011121314151617181924 ... LastLast
Results 196 to 210 of 761
  1. #196
    audiotek's Avatar
    May 2011
    Quote Originally Posted by obdrs View Post
    Can you tell me where did you buy HCT125M and what is manufacturer ?
    I bought in ebay.com, and the brand is Texas Instruments.
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
  2. #197
    Nov 2012
    Yea friend cracked 88 (think he just figured out from at and add to at his board works without 88). I gave a copy of one of his soft to a close friend and it got leaked and does not trust anymore.
  3. #198
    leandroks's Avatar
    Feb 2010
    Brazil
    perfect- works 100%
  4. #199
    May 2011
    Quote Originally Posted by audiotek View Post
    Working now, thanks for info
  5. The Following User Says Thank You to obdrs For This Useful Post:
    fluorescent (25th April, 2019)
  6. #200
    Sep 2009
    hi,
    work with convert usb-port parallel ?
  7. #201
    cubica1's Avatar
    Feb 2012
    Serbia
    Friends, is any of us has a newer .lib file than v4.01??? Because, if you just reflash HW it means nothing without changing .lib file...a new SW will work (ok, counter will be reseted) but all new functions will be NA marked
    cuby
  8. #202
    Sep 2009
    hello,
    I bought jtag on ebay. with parallel converter usd.
    JTAG programmatore | eBay
    but I can not connect.
    the jtag, it works with the convertirore usb?
  9. #203
    Dec 2009
    No, but heard that the perfect one does but, again, it's much more expensive than your jtag.
  10. #204
    Jan 2010
    hello is look from chines compagny but look is
    CARPROG FULL V5.31(with all Softwares activated full Adapters) is the newest version of carprog in 2013, more car models than v4.01, and add count reset cable
    it is can
  11. #205
    DK Veteran elchip's Avatar
    Nov 2009
    EU
    CarProg can be full reflashed over USB even is locked with counter "0" ;-)
    Regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
  12. The Following User Says Thank You to elchip For This Useful Post:
    PierreTheron (13th October, 2013)
  13. #206
    tehnosoftex's Avatar
    Romania
    Can you be more specific?
  14. #207
    Oct 2012
    Quote Originally Posted by elchip View Post
    Regard's
    how you can make this ?
  15. #208
    Sep 2009
    Does anybody know if it is possible to update the firmware of a clone CARPROG FULL V4.01 to work in software V4.74 and even V5.31. The new versions of software in these clones really are FULL?
  16. #209
    Nov 2010
    I have tried to reflash with ULINK2. Connected successfully , but it supports only hex files. Maybe someone can give me hex file of AT91SAM7s256 or convert it from bin? Thanks
  17. #210
    Nov 2010
    Anyway I have converted by myself. So if anyone will need hex file of carprog, here you go. AT91SAM7s256.zip
  18. The Following 3 Users Say Thank You to aasass For This Useful Post:
    BimmerGT1 (27th August, 2013), blaneslectronica (23rd May, 2016), Grucha1982 (24th September, 2016)
