Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
  1. #46
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    5.00.8 r2 is stable ,easy menu ,has more coding and adaptions , also has A*toD*ta built into it , only autocom 2013 is real all others cooked rubbish
    here u r m8 try it , might need to search for how to install cant find notes right now but even the old ones were the same
    found it
    copy your autocom f/w into wow's f/w folder ( C:\wow5.00.8R2eng\ac_diagnosis_module\firmware ) and overwrite then you can use both programs without f/w problems
  2. The Following 5 Users Say Thank You to smirnoff_rules For This Useful Post:
    biela (22nd October, 2016), daniel guerra (5th August, 2016), jodank (10th August, 2016), pulsar2000 (4th August, 2016), seal777 (12th October, 2016)
  3. #47
    Jun 2012
    Downloading, Cheers, will give it a try
  4. #48
    Nov 2014
    Newcastle UK
    hi again peeps
    im now looking for a flasher tool ive been looking at the Galletto V54 but i am also looking at the SMPS MPPS V13 would the MPPS do the job for reading and writing ?
  5. #49
    Jun 2012
    FGTECH any time, mpps limited, doesnt cover Fords.
    mpps will do your Renault tho,,,
    depends on why you buy, if your looking just to do your car mpps, if you want to cover all angles and better range of ecu`s go with fgtech,
    also fgtech BDM and Boot mode,
    Mpps OBD only
  6. #50
    Jul 2016
    Hi.
    I have a question.
    If I use mpps to RENAULT 1.9 DCi EDC16(read/write) ,is also gotta save injector coding before?
  7. #51
    Apr 2010
    belgrade,serbia
    hi,only way to get codes back is that someone send you injectors codes read by galeto ,than you write that file by galeto ,and thats all ,than you can change codes with any diagnostic or you dont have too change ,it is bosch injectors and every are similar.other way is that you read with galleto ,options injector code ,not flash ,on some other 1.9 dci and again write it by galleto in your ecu .I have file but cant send you before monday
  8. #52
    Babos's Avatar
    Mar 2012
    Not all that help! i see few times not kess not fgtech cant to write back injectors.
    there is one way to do all manual
  9. #53
    Jun 2012
    Quote Originally Posted by pulsar2000 View Post
    Mpps OBD only
    Oh yes,,, Forgot to mention , you will lose inj codes mpps ,for sure,
    Babos is correct, only way is manual for sure, But good quality kess use Tool option to backup or Fgtech inj code read to backup....write etc
    Forget the $15 mpps. mate
  10. The Following 2 Users Say Thank You to pulsar2000 For This Useful Post:
    chrisl87 (11th August, 2016), smirnoff_rules (10th August, 2016)
  11. #54
    Nov 2014
    Newcastle UK
    ive ordered the MPPS V13 metalbox version :s but as previous when i lost codes and with me now having my delphi / can clip ill be fine just reprogramming them back in with either one of them wont i ?
  12. #55
    Oct 2010
    Quote Originally Posted by smirnoff_rules View Post
    found it
    Hi smirnoff
    i downloaded and am trying to install , i now think its asking for installation path but its in what appears to be greek - does this mean i hve wrong file or once installed will it be the eng version ?
    cheers and apologies for being a pain
  13. #56
    Mar 2008
    birmingham
    just press enter m8 unzip is different but install is english
    if its asks for pass its
    PASSWORD = motordig
  14. #57
    Oct 2010
    ok, think i guessed my way through it i did get a dos error and no desktop shortcut but so far it seems to be in ok...........
  15. #58
    luca22's Avatar
    Dec 2010
    Quote Originally Posted by Babos View Post
    Hello Friend
    My oryginal KESS do that ecu without problem, tested many times and no need to read inj codes...
    Regards
    Luca
    PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
    AND REPUTATION BUTTON (starr)
  16. #59
    Oct 2010
    thanks for the link and reply , its appreciated.
    apart from the 1st glitch the only part i am not 100% of is note 11, activate the following switches
    i get the part of switching your generated digit pairs into the string but not sure which string to enter - the one in photo (i used this) or all 4 from note 11 ?
    i switched in the 1430 FW and its worked so far to update my 100e chinese vci and read 07 fiesta as a test.
    cheers
