SGSH Bouquet 500C/800HD/800SE
This topic is closed.
Actually, I manually added the channels thru a scan and it turned out fine. Is there a version for dm500c? If I add a bouquet with SH style numbering, will the order be messed up after updating with the plugin?
Sent from my GT-I9300 using Tapatalk 2Comment
It still follows the sh style numbering but the layout maybe different from yr existing ones. The plugin also install the new picons as well. Do a backup of yr bouquet before u run the plugin in case u want to revert back.Comment
Right click on all the channel list/ set keep flag option to ON/ok this is to keep the channel intact/u can go on edit the service data, under flag option only Tick the 2nd box H (hide) if u don't want the channels to be display on your box like eg. those demand channels/save.Originally posted by ckhub15
Master DBTraitor, is there a way to hide the reserved channel permanently? I realized it will come back after rebooting from start
When u done editing all the channel list + bouquet & u r sure about it ,select FTP/Tick auto reload setting enigma 2 for 800 series only/send files to Dreambox/reload settings on Dreambox/restart enigma.
For 500 series after reload command/do not select reboot/ go to the box power off it wait for 10 sec than on back the power,Do not create any bouquet for E1 500C or else u can't use the 3 digit direct channel selection.
There will be some minor mistake entry don't worry edit it,then send it again. Congratulation now your list is intact the same as SH channel list.
Sent from my GT-I9305 using Forum RunnerComment
As for me master i will scan box, when done / restart box / PC side open new folder rename it eg Bouquet 11112012 dummy / open DB edit, (FTP) receive the newly scan channels to the new folder / open 2nd DB edit / open my existing bouquet then just copy paste any new channels to my existing bouquet / edit / send to box that itGood to try. What I did usually is manual scan the freq then ftp to dreamEdit. find the chn at lower part of bouquet edit the chn nbr near the lower right corner at center of page to the LCN (Local Channel Number) and ftp back to box.
With experiment then comes experience, it all take less than 10min and all done liao.
The joy comes when u can do chn edit yrself with this proud achievement. Good luck.
I hv all my 4xDB in home connected to Router 24/7 with Vionet wireless, so I dont even hv to bring the box to my table, I just do it over with my working computer via this router. Also online to restart the DBs. this way, can view, stream and access media files via wifi and watch movies anytime in any room via ip access. eg. downloaded to main computer from U-tube, funshions, pps, tvboxnow, hv all the latest HK series 2hrs after broadcast in HK. FoC some more. SH Vod still hv to pay!!!
However even if you failed, can always go back to Master UU161's online update. He is so kind to edit and put up almost immediately after rcvd new infos. Big Thanks to Master UU161.
am using same as ur method before i use harder way manual editLast edited by uu161; 11 November, 2012, 05:55.if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
Yea, i using same method too... haha
By the way, Astro have you updated both 500c and 800 service and bouquets in this thread? You last post was updated 18082012Last edited by DBTraitor; 11 November, 2012, 06:58.A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
Yup just added might not be the same as uu161 as i still use
List of StarHub TV and mio TV channels - Wikipedia, the free encyclopedia
as reference u can download from 1st postLast edited by ASTROBOX; 11 November, 2012, 07:34.Comment
I think this is the official link can't find any others
& thanks just came back yesterday anyway just keep up all those good job updating in this forum no need to wait for me u guys r more expert than me thanks for sharingComment
Dreamboxedit guide
800
Dreamboxedit for 800HD and 800SE - YouTube
[ame="http://www.youtube.com/watch?v=IlIGkaGKwHA"]Dreamboxedit for 800HD and 800SE - YouTube[/ame]
500
Dreamboxedit guide for 500c - YouTube
[ame="http://www.youtube.com/watch?v=OpjjhS2T-V8"]Dreamboxedit guide for 500c - YouTube[/ame]
Latest service and bouquet files by ASTROBOX (For SG use only)
Last edited by DBTraitor; 11 November, 2012, 14:56.A wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
