SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • sdcorp
    • Oct 2012
    • 6
    #241
    Originally posted by edlimym
    hi there, i am not sure about Blackhole image coz i am using Newnigma image. but anyway, go to Download section and get that TSPanel ipk file. put it inside a thumbdrive. plugin the thumbdrive to your DM box and startup the box. once fully started, navigate around your Blackhole menu to install this plugin offline, meaning either thumbdrive or int/ext hdd. hopefully you can install TSPanel.
    if that is successful, inside TSPanel got an option to blank off your current password. meaning that userID is ROOT and password is a 'BLANK'. hopefully it works for you. cheers.
    ps - no need to install this plugin via DCC. install using direct Blackhole Menu.
    Thanks! Will try that. Yesterday did try to crack the passwd by brutus but it didn't work also. signz! Will try yr method and post result. Once again, Thanks for your help!
    • vins
      #242
      Sorry for the noob question.
      But does Free shipping by EMS to Singapore DM800hd C with Singapore Image HD channels Gemini 5.1 Bootloader 84 Set top box-in Set-top Boxes from Consumer Electronics on Aliexpress.com
      work with SGSH Bouquet?
      Thanks.
      • ypvs125
        • Dec 2010
        • 506
        #243
        Yr answer to the question is already state on the thread starter.
        All discussion on SGSH Bouquet only applicable to
        Dream Multimedia (DM) 500C/800C HD/800C SE only.
        Do not use this method if box is not Dream Multimedia model.
        • thyewah
          • Oct 2012
          • 11
          #244
          Newbie here.
          Where can I buy this box?
          Prefer 800SE.
          Any kind souls can PM me the info.
          Thanks.
          • garysoh
            • Oct 2012
            have read tons of the forum, but still cant/ donno how to use PM
            • DBTraitor
              • Feb 2011
              • 616
              #246
              you must make one post and then after that left click on the member's name.. thats all... No need to read so deep
              A wise man learn more from a foolish question than a fool can learn more from a wise answer.
              • simongoh
                • Oct 2012
                • 4
                #247
                Hi Guys, I'm new to this, just got my hand on a unit of 800HD SE
                • DBTraitor
                  • Feb 2011
                  • 616
                  #248
                  Welcome.....
                  Its will be good if you can learn how to do ftp and load a channel update plugin into your new 800SE. By doing this, updating of channels is only a press of a button.
                  • sunray
                    • Oct 2012
                    Hey guys, I'm new here. Greetings to you all.
                    I have a DM500C box and I am thinking of updating my current box to the latest SH channels. I saw an upload "500C Updated Channels and Picon 14 Oct 2012" by DBTraitor and would like to know how to go about using ths file.
                    Do I use the same method as outlined in the thread starter? Would appreciate some advise.
                    Thanks.
                    • jatrophaseed
                      • 589
                      #250
                      Channel 131
                      Sorry Master 161,
                      That overdue long ago chn 131 is back, I apologise to ask u to delete the chn, it seems back again.
                      Chn 131 unknown
                      • bornno1
                        • Oct 2012
                        #251
                        anyone notice some hd channels are blank?
                        • uu161
                          • May 2012
                          • 372
                          #252
                          Originally posted by jatrophaseed
                          Sorry Master 161,
                          Chn 131 unknown
                          it ok lets wait till channel info confirmed then add back 131.
                          if you like the post use the Like button located bottom right corner of each post
                          if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                          • eem19802000
                            • Apr 2012
                            Hi Bros,
                            can i ask who've the latest image of DM500c with latest Bouquet?
                            Thanks in advance
                            • ASTROBOX
                              • 163
                              #254
                              Sorry Master 161,
                              Chn 131 unknown
                              Maybe SH is still negotiating for the right price on this channel hehehehe.......
                              • ypvs125
                                • Dec 2010
                                • 506
                                #255
                                Originally posted by eem19802000
                                Hi Bros,
                                Thanks in advance
                                U can try this image with latest bouquet.
                                SG-dm500c-OpenPLi-Turko-v26.img
