SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • DBTraitor
    • Feb 2011
    • 616
    #226
    Latest E1 500c Service and Bouquet + Picons
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
    • uu161
      • May 2012
      • 372
      #227
      E2 100x60 Picon for
      1)143 ANC
      2)145 Cinema One Global
      if you like the post use the Like button located bottom right corner of each post
      if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
      • DBTraitor
        • Feb 2011
        • 616
        #228
        i just notice channel 131 Sony MAX is no longer available. I thought its quite new channel as well?
        • jatrophaseed
          • 589
          #229
          Chn 131 was not implememted. Can delete it.
          • ghgan
            • Oct 2012
            Can DM501-C HD do recording?
            • sdcorp
              • Oct 2012
              • 6
              #231
              Unable to connect to Telnet by DCC
              Hi! Had face a problem with the FTP & Telnet. When i input the user ID : root & Passwd : dreambox, it says FTP connected but FTP disconnected due to wrong ID & PW. Anyone have any clue?
              Thks!
              • ypvs125
                • Dec 2010
                • 506
                #232
                Thks!
                Which box r u using?
                • sdcorp
                  • Oct 2012
                  • 6
                  #233
                  HI! I am using DM800HD.
                  Thks!
                  • edlimym
                    • Feb 2012
                    • 29
                    #234
                    Thks!
                    what is your current image? go and download TSPanel and standby.
                    • sdcorp
                      • Oct 2012
                      • 6
                      #235
                      Hi! Accordingly to the specs, it stated " With Boothloader #76 ,Sim version 2.01 , Image 5.0 or higher" When i boot up, the screen says "Blackhole" starting egnima2.
                      I can't install any plug-in as i cannot excess files in the dm800hd thru DCC. Please help.
                      Thks!
                      • ultrakiasu
                        • 128
                        #236
                        Thks!
                        Download a FTP client, (ie. FileZilla, WinSCP, or commandline psftp)
                        FTP the ipk file into /tmp
                        Telnet to the box (ie telnet dm800)
                        If there is no telnet in your system, download Putty, its a freeware, available in PC and Mac.
                        Login as root and issue this command
                        cd /tmp
                        opkg install abc.ipk (assuming abc.ipk is your plugin file)
                        Then reboot.
                        The plugin will be listed in the Setup, Plugin menu.
                        (Depends how the plugin was written).
                        • sdcorp
                          • Oct 2012
                          • 6
                          #237
                          cd /tmp
                          Then reboot.
                          Hi! Thank you for your help! Before i try that, can i ask if these FTP client still need to log in with the default password? it seem that no matter what ftp cleients i used, it always have the same problem, ie. wrong user id or password. And if i can't connect to ftp or telnet, there is no way i can transfer files. Again, thank you very much for your help!
                          Thks!
                          • alienated
                            • Mar 2012
                            • 29
                            #238
                            If the default root/dreambox has been changed, you can try the file manager in dreambox and modify the passwd file.
                            Search the web on how to modify the passwd file.
                            • sdcorp
                              • Oct 2012
                              • 6
                              #239
                              Well, i have confirmed with the supplier that the id & passwork is "root" & "dreambox" and i did not do any changes to it, but still cannot work. sighz! anw, will try again. Thanks!
                              • edlimym
                                • Feb 2012
                                • 29
                                #240
                                Thks!
                                hi there, i am not sure about Blackhole image coz i am using Newnigma image. but anyway, go to Download section and get that TSPanel ipk file. put it inside a thumbdrive. plugin the thumbdrive to your DM box and startup the box. once fully started, navigate around your Blackhole menu to install this plugin offline, meaning either thumbdrive or int/ext hdd. hopefully you can install TSPanel.
                                if that is successful, inside TSPanel got an option to blank off your current password. meaning that userID is ROOT and password is a 'BLANK'. hopefully it works for you. cheers.
                                ps - no need to install this plugin via DCC. install using direct Blackhole Menu.
