SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • novaol
    • Dec 2012
    • 110
    #796
    Tks buddy.. you are a great help.. Files in picon folder updated on the same archive. Cheers
    Originally posted by ypvs125
    E1 picons for the 2 channels.
    [ATTACH=CONFIG]240823[/ATTACH] Ch 832- Dragon TV
    [ATTACH=CONFIG]240822[/ATTACH] Ch 851- now Hairun
    • thyewah
      • Oct 2012
      • 11
      #797
      Ch 116 Suria HD
      Ch 154 Ch 8 HD
      Ch 156 Vasantham HD
      • moviesg
        • Jul 2012
        • 60
        #798
        How to add the channel manually
        Sent from my SM-N9005 using Tapatalk
        • avo24
          • Feb 2010
          • 28
          #799
          Just got a question in mind. If my dm500 had password lock, am I able to reflash the image? Or isthere anyway to remove the password in other way then reflash it??
          • novaol
            • Dec 2012
            • 110
            #800
            Yes you can still flash a new copy of the firmware but you need someone else's magic files for it to work if not you will only get FTA channels. Hope that helps.
            • avo24
              • Feb 2010
              • 28
              #801
              Happy chinese new year guys . May all our box works fine this yr hahaha
              • cavok100
                • Jan 2013
                #802
                Latest E2 Bouquet and Picons
                4shared.com - free file sharing and storage
                Added 2 latest channels:
                Ch 832-Dragon TV
                Ch 851- now Hairun
                Removed:
                Ch 523- ITV Choice
                Hi, the download is no longer valid. Can you upload again with new link?
                • DBTraitor
                  • Feb 2011
                  • 616
                  #803
                  Download from here
                  Services and Bouquets - Downloads - Digital Kaos
                  A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                  • deen1977
                    • Dec 2013
                    • 4
                    #804
                    hi Bros.... Anyone can upload latest picons for HD800SE ???
                    • uu161
                      • May 2012
                      • 372
                      #805
                      anyone notice Nat Geo Adventure changed Nat Geo People ?
                      or i outdated
                      if you like the post use the Like button located bottom right corner of each post
                      if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanks
                      • jatrophaseed
                        • May 2010
                        • 589
                        #806
                        Hi Master UU161, yes, it is Nat Goe People now. Thanks, I didnt notice....
                        • cavok100
                          • Jan 2013
                          #807
                          Just received phone call from SH to replace old setup boxes (more than 3 years old) in my office. They said it's compulsory to change as they are changing "signals" in June which our current boxes won't be able to receive. N3 D-day is coming in June!
                          • jatrophaseed
                            • May 2010
                            • 589
                            #808
                            June in time for WorldCup!
                            Sent from my GF-2 using Tapatalk
                            • howpeter
                              • Jun 2011
                              • 63
                              #809
                              Hi All Expert, I am very new to Dreambox technology, I have a Dm800Hd Pvr. Recently got it repair from a problem, 'No CA found'. Now i am able to boot up and go to channels. But all the channels appear black, is it i have to install this ' Sg E2 Bouquet with HDs' , then only i am able to view the channels?
                              Thanks very much!
                              • novaol
                                • Dec 2012
                                • 110
                                #810
                                E2 boutiques are meant for 800 series box. Yes do install it and your channels will be shown though only available is the standard channels. Cheers
                                Originally posted by howpeter
                                Hi All Expert, I am very new to Dreambox technology, I have a Dm800Hd Pvr. Recently got it repair from a problem, 'No CA found'. Now i am able to boot up and go to channels. But all the channels appear black, is it i have to install this ' Sg E2 Bouquet with HDs' , then only i am able to view the channels? Thanks very much!
