SGSH Bouquet 500C/800HD/800SE
This topic is closed.
  • pirsquared8
    • Feb 2013
    • 114
    #706
    Originally posted by ahhoe
    I have a DM800HD-C. Trying to update my channels to watch Bee.Pii.LL
    Downloaded E2SG-Bouquet-082013
    Dreambox set : Pluck in Lan cable. Hold power button + pluck in power adapter.... get ip 192.168.0.108
    Dreamboxedit : Confirmed 192.168.0.108 is set. Username (root), password (dreambox), selected enigma2, http port 80, ftp port 21, SAVE!
    Clicked FTP button --> confirm directory point to right folder, ip address correct, click "Send files to dreambox", I get this message "Connecting to 192.168.0.108.
    Could not connect to Dreambox. Check IP Address, network settings and status of Dreambox."
    Any1 know what went wrong?
    Did you read post #692 above talks about a newbie guide?
    Always do a complete image backup (which will include the magic beans files) before you attempt to do anything
    Also why were u updating yr image anyway? uodating image has nothing to do with the BP oil Elle magazine pages
    • avo24
      • Feb 2010
      • 28
      #707
      Originally posted by pirsquared8
      the no. u quoted are measured in dB (decibels) while SNR (Signal to Noise Ratio) is measured in %
      In my OpenPLi image by master y..125 there is a setting on Menu -> Setup -> System -> User Interface -> Show SNR percentage instead of dB values ...... is set to "NO"
      from my set 37.6 dB (channel U) correspond to 89%
      so for yr 34-36 dB could correspond to 80% roughly ??? just guessing
      My box on channel u 99%, football channel 99% . But bee pee la around 74%- 80% and sometime at 0% ( tuner fail) still unable to watch ; ( .. any tip guy
      • pirsquared8
        • Feb 2013
        • 114
        #708
        What % of the time is yr tuner @ 0% i.e fail?
        • avo24
          • Feb 2010
          • 28
          #709
          Finally I fix my soccer channel error when it 80% .. need so blend of my cable wire..
          • pekakbadak15
            • Mar 2012
            • 103
            #710
            Master 125 has previously posted 3 bouquet. Did u try them? Different set do make a different on my box.
            • digi16
              • Jan 2013
              • 13
              #711
              In DBedit option you can test ip connection? One other advice from posted before was to use older version
              • ahhoe
                • Oct 2011
                • 13
                #712
                Ee....I thought this contains the new channel list.
                Cos I tried updating manually from the player.. no response.
                Sent from my GT-N7105
                • pirsquared8
                  • Feb 2013
                  • 114
                  #713
                  master y...125 published a Newnigma3.3.1 800se image which had the BP Oil Elle Magazine pages in them. No "superman" keys tough. u can try this image. good luck
                  what set r u using?
                  • ahhoe
                    • Oct 2011
                    • 13
                    #714
                    what set r u using?
                    Thanks. I go do a search.
                    I am using dm800hd-c
                    • pirsquared8
                      • Feb 2013
                      • 114
                      #715
                      Now my SNR is 72% (30.6db) AGC @ 42% and main bee peeing page is fully pixelated and speech stuttering :-(
                      Believe our Green Fat Pipe is purposely smoking us around with their lousy smoke signals. Did not change or touch anything on my set.
                      Sometimes u win sometimes u loose
                      • jeffchiang
                        • Aug 2013
                        • 14
                        #716
                        Hey guys, so DM800HD se confirm can get all 8 EPL channels?
                        • Asbar
                          • Jun 2012
                          • 60
                          #717
                          mine is 89% & 93%.. no pixelated on B*P*L channels.. all good.. the rest all normal..
                          • Asbar
                            • Jun 2012
                            • 60
                            #718
                            yes bro.. i'm using Dm800HD SE.. all good..
                            • pirsquared8
                              • Feb 2013
                              • 114
                              #719
                              Well i just tightened the end of the cable to my set and moved the cable a bit to kind of move the tuner inside am now getting SNR of 76-78%.
                              looks like touch and go here and no secret recipe for low signal reception.
                              blame the green smoking fat pipe people for bot giving us different signal strengths for different pages
                              • jeffchiang
                                • Aug 2013
                                • 14
                                #720
                                That's great to hear! Thanks bro!
