SGSH Bouquet 500C/800HD/800SE
This topic is closed.
Yes you can still flash a new copy of the firmware but you need someone else's magic files for it to work if not you will only get FTA channels. Hope that helps.
Hi, the download is no longer valid. Can you upload again with new link?Latest E2 Bouquet and Picons
4shared.com - free file sharing and storage
Added 2 latest channels:
Ch 832-Dragon TV
Ch 851- now Hairun
Removed:
Ch 523- ITV Choice
ThanksComment
Download from here
Services and Bouquets - Downloads - Digital KaosA wise man learn more from a foolish question than a fool can learn more from a wise answer.Comment
anyone notice Nat Geo Adventure changed Nat Geo People ?
or i outdatedLast edited by uu161; 8 March, 2014, 23:52.if you like the post use the Like button located bottom right corner of each post
if you wish to thanks kindly use the thanks button located bottom left corner of each post instead making a post for thanksComment
Hi All Expert, I am very new to Dreambox technology, I have a Dm800Hd Pvr. Recently got it repair from a problem, 'No CA found'. Now i am able to boot up and go to channels. But all the channels appear black, is it i have to install this ' Sg E2 Bouquet with HDs' , then only i am able to view the channels?
Thanks very much!Comment
E2 boutiques are meant for 800 series box. Yes do install it and your channels will be shown though only available is the standard channels. CheersHi All Expert, I am very new to Dreambox technology, I have a Dm800Hd Pvr. Recently got it repair from a problem, 'No CA found'. Now i am able to boot up and go to channels. But all the channels appear black, is it i have to install this ' Sg E2 Bouquet with HDs' , then only i am able to view the channels? Thanks very much!Comment
