FYHD 800c-vii latest firmware
  • fabz87
    • Jul 2013
    • 9
    #46
    Hi Bros,
    Just want to update, I've managed to get ALL BPL channels as of now.
    What I did:
    Update the FW using the one cyrus uploaded on the 1st post (not bro jatrophaseed one, but the 0508 one).
    Manual scan 135500, 6090 symbol, QAM leave it 256.
    I guess the signal has stabilized (as what bro jatrophaseed had predicted).
    • sonicwinter
      • Aug 2013
      • 4
      #47
      Originally posted by fabz87
      Hi Bros,
      What I did:
      I did the same too but my image is not stable. It's freezing and jittery.
      Will try it with a new cable tonight. Keeping my fingers crossed.
      • chinwm
        • Aug 2013
        • 11
        #48
        hi peachmaster is your issue resolved? i'm also facing the same issue...
        Originally posted by peachmaster
        Hi all,
        I just did a flash on my HDC-800 with this fw and now it cannot detect any channels at all.
        I'm stuck at the Installation Guide menu.
        Before upgrading I've noticed that the Min freq was xxMhz (2 digits) to Max xxxxMhz (4 digits) for Full Scan.
        After upgrading the Min freq is 98000Mhz to 786000Mhz and the Symbol (Ks/s) is defaulted at 6875.
        I've tried Restore Factory Default, reflashing the fw again and hard reboot multiple times but to no avail.
        Can any senior members provide some advice if this are the correct settings?
        Or is there additional steps that I missed?
        Model: HS-FTA-AVS+DVB+C
        SW Ver: HDC-8XX V2.0
        HW Ver: HDC-8XX V2.1
        SW VersionTime: 2013-08-05
        Please help!
        • chinwm
          • Aug 2013
          • 11
          #49
          hi ronniecorny, i tried doing...still no avail....
          Originally posted by RonnieCorny
          hi
          you may want to try to change the symbol rate from 6875 Ks/s to 6090 Ks/s before starting the full scan.
          good luck.
          rgds,
          - ron
          • shidevil
            • Aug 2013
            • 84
            #50
            Do you have a Starhub subscription?? Or previously??
            • sonicwinter
              • Aug 2013
              • 4
              #51
              I've been advised to buy either a signal booster or a better quality cable to solve this problem of the jittery and distorted images.
              Might go down to Sim Lim tomorrow to get it. Any recommendation which is better or what I should get?
              Thanks in advance.
              • badboys8908
                • Feb 2013
                • 7
                #52
                Hi Bros,
                What I did:
                Thanks Bro, you method works for my MHD600C. Now i can view all BPL Channel including Multiview. Thanks again...cheers
                • AndyWolfe
                  • Aug 2013
                  Subscribe to mio then no problems liao =D
                  • Crazyhanz
                    • Aug 2012
                    bro just to check. Is your's the white colour box?
                    • sonicwinter
                      • Aug 2013
                      • 4
                      #55
                      Problem solved thanks mostly to kind advice from bro inq.
                      Ready for new season
                      • chinwm
                        • Aug 2013
                        • 11
                        #56
                        previously..
                        • peachmaster
                          • Aug 2013
                          #57
                          Hi chinwm I'm still stuck with the same problem. I've tried scanning at different Symbol rating 6090..etc but still can't detect any LCN.
                          I'm trying to look for the previous ver of the firmware to revert it back or copy the firmware from another box.
                          • chinwm
                            • Aug 2013
                            • 11
                            #58
                            many thanks for your reply...if you have resolve issue, please share with me...thanks...i believe our box is of an older gen...that's why this new firmware can't work with our box.
                            • anathema
                              • Aug 2013
                              • 13
                              #59
                              Hi, can the FW work on FYHD-HDC-800e white box?
                              • anathema
                                • Aug 2013
                                • 13
                                #60
                                fabz27, is yours a white box or black box? What is your model number?
