FYHD 800c-vii latest firmware
  • dt1986
    • Jun 2012
    • 7
    #106
    Originally posted by fabz87
    Just on the TV and checked mine. Working fine with no issues. I'm having the same box and using the exact same firmware as you are. Maybe your coaxial cable?
    Hi fabz , another problem is i have 2nd set in my room , i update the version , now search only show (ondemand)
    • pirsquared8
      • Feb 2013
      • 114
      #107
      Originally posted by swq26
      Hi guys.. I'm new here. I have black colour fyhd 800c-II. Can i get BPL? Where can i get the new firmware? Appreciate it guys.
      yes agreed with Agallivant. I just did a delete all "pages" and then an automatic scan. wah lah all pages including BP Oil Elle magazine pages :-) Try this. Advice is not to play around with fw upgrade but with pages update. the risk of bricking is too great for older models like fyhd 800c-ii
      • chrome08
        • Jan 2013
        • 13
        #108
        Originally posted by Enjoy83
        Have read a lot in this forum and thought I should share some of my newbie experience with my white FYHD that was bought last month (before knowing this wonderful site).
        Casing - MHD 600-C
        Software information when bought:
        Model: HD-FTA-AVS+DVB-C
        SW: HDC-888 V2.0 TNDT
        HW: HDC-888 V2.1
        SW versionTime: 2013-07-17
        And I updated with the latest firmware found dated 05082013. Unfortunately, jatrophaseed removed his version of FW as I THINK his is a better version. Initially, I was unable to update FW. The box just reboot and nothing happens. The reason for that is due to my ext HDD is in NTFS. I then changed to my SD card formatted to FAT32 and updating was a breeze.
        Went straight to manual scan and followed the instructions on 135500 and symbol 6090. Got the channels immediately. Did another full scan and the first 6 channels are there. The other 2 channels are parking at 1000+ but I can't confirm as there's no broadcasting yet and I don't watch soccer actually. Just doing all these for experiment.
        Points that may help to improve signal:
        If possible, don't use a splitter. (I'm going to get a good quality splitter this weekend. Any to recommend?) The signal quality drop from 70+db to 10-20+db after getting split on my splitter(poor quality i think). This is tested on 135500,6090 since these are the only channels left that are not clear on my box. I used to have problems with channels from 666mhz (download SGSH channel list from the downloads section) but they are solved with a change of coaxial cable.
        Don't use a converter (male->female or vice versa). The lesser the components, the better it is. Get the exact connector type for your coaxial cable connection.
        Don't buy excessive length for your coaxial cable, buy what you need. Longer cable = more signal lost.
        Buy better quality coaxial cable.
        Hope it helps.
        try to scan using the frequency 135000 mhz, and symbolrate 6090, it works for me, not sure if it will work for you too
        • isc00581
          • Aug 2013
          Hi all,
          I am able to receive 6 BPL channels yesterday! After trying for almost 2 weeks!
          • sldlee
            • Aug 2013
            Hi all,
            I've tried updating with FW : MVHD-072013-SCV_HDC3000L_M_L1.1_V2.5.0_CID-21009.abs for my FY HD800C-V and I manage to get all EPL channels.
            Question : Anyone tried updating their FY HD800C-III ? Which FW version to use? Pls advice.
            • shuanglsg
              • Aug 2013
              #111
              why i insert my usb cant detect the file only say usb detected
              • dt1986
                • Jun 2012
                • 7
                #112
                finally resolve my issue , by full scan again , bpl back
                • nelsonhtb
                  • 44
                  #113
                  Press Menu button, last icon USB should be the one to list whatever type of media files you want to open.
                  • DaNiAl6
                    • Aug 2013
                    #114
                    How do u delete all "pages"? its the same step for HD600-c rite?
                    • denverp
                      • Jul 2013
                      #115
                      After upgrade, having problems with PVR pre-set recording. Sometimes cannot play back the recording at all, stuck at "init...". Also, the "time shift" doesn't work.
                      Anyone else has the same experience?
                      • DBTraitor
                        • Feb 2011
                        • 616
                        #116
                        Thats why, as mentioned by senior in the forum. If your box does not have issue, dont fix it.
                        There is no need to upgrade firmware unnecessary unless the new update has something that benefit you and you are well aware what are the changes.
                        Otherwise updating of channels is good enough.
                        Taking chance to upgrade firmware is risky as you do not know whether it is meant for your box or not. Will it brick your box. Will you lose all the data and keys etc
                        A wise man learn more from a foolish question than a fool can learn more from a wise answer.
                        • ahkok
                          • Aug 2013
                          #117
                          After flashing firmware, my MVHD800C-V box cant boot up. Can anyone kindly advise how to recover?? Can i connect to the pc or laptop to flash the box with some special software?
                          • shidevil
                            • Aug 2013
                            • 84
                            #118
                            Read the top post. Sadly u shouldn't flash the firmware.
                            No u can't connect to anything.
                            • ahkok
                              • Aug 2013
                              #119
                              my mistake to flash the firmware.
                              Thanks for the info, need to get another new one then. Anyone need spare hardware parts. Haha.
                              • tigerwoods
                                • Sep 2013
                                Poor images
                                Just got a new PVR set from SZ. Turn it on, all the channels images jumping. Any advise pls
