seeking to get all setup using wireless setup and looking like sly etc with all plugins
need assistance in getting wireless setup with "the c** thing" and ready to go - have managed to flash the sly skin version so far
the box recognises the dongle previously in my f5s and finds my router but can't configure
New 2015 Enigma2 Boxes DVB-C and DVB-S2 Zgemma Star H1 & 2S
Use an Externally powered hard drive at least 500gb especially if your thinking about doing a lot of recording, a 2 Hour program in HD could take up anything between 7gb to around 14gb
EPG takes up very little spaceLeave a comment:
What about the capacity requirements?...
For instance how much would be required by the EPG and other online TV plugins etc?
How much capacity would a 2hr programme require?Leave a comment:
I dont see why not but maybe a good idea to try a powered external drive rather than having the USB supply power to the drive and wi-fi stick, Puts less strain on the PSU unitLeave a comment:
Is it possible to have the EPG and recording 2 programmes, pausing capability etc from a single USB stick/drive whilst the other port is occupied by the Wi-Fi?Leave a comment:
Same size apparently with an added DVB-C/T/T2 tuner specs:
- Fully MPEG-2, MPEG-4 & H.264 Compliant
- DVB-S & DVB-S2 Complaint
- 1x HD Satellite (DVB-S2) Tuner & 1x DVB-T / DVB-T2 / DVB-C Hybrid HD tuner
- 751MHz Broadcom Dual Threaded MIPS Processor
- 256 Mbyte NAND Flash & 512 Mbyte DDR3 Ram
- Linux Open Embedded
- Output Resolution: Full HD 1080p, 1080i, 720p, 576p, 576i & 3D Ready*
- 1x Smart Card Reader
- 1x Common Interface (CI)
- External IR Sensor
- HDMI Output
- Dolby Digital Plus compliant via optical S/PDIF output
- 2x USB 2.0 Ports (1x front and 1x rear)
- Ethernet Port
- Unlimited Channel Memory
- Composite Video Output with Audio Channels
- Super sensitive tuner for very weak signals and weak transponders
- Less than 1 second channel change
- DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
- Extended EPG and programme reservation on EPG
- Support for multiple audio language broadcasts
- Supports PAL/NTSC systems
- Parental Control
- SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
- 4:3 & 16:9 screen formats
- Timer & multi-event timer functions
- Automatic FEC and PID detection and manual entry of PID values
- Real time clock
- Teletext & Subtitle support by OSD and VBI
- LNB short circuit protection onboard
- Universal Remote Control
- 1W Standby power consumption option
- 12V DC
Leave a comment:
i have the sat version of the nano se to replace my solo,wonder will that box be small and have a free magic eye.
curious if anyone using zgemma on cable in ireland??Leave a comment:
The only one i know for sure at the moment is the Technomate Nano - SE - Combo which runs a later chipset than the Zgemma and is also a Dual core 750mhz processor similar to the already single sat version the Nano SE which for speed wipes the floor with the Zgemma but expect to pay a little more for a Korean built receiver as with anything Quality comes at a priceLeave a comment:
I would try and flash again sounds like you have a corrupt image.
There is a bootloader on the Zgemma website that might do the trick.
AndyLeave a comment:
Which receivers are you expecting to hit the market shortly?
Does anybody know if it's possible to record one watch another and have the 7-day EPG option with a Wi-Fi set-up occupying one of the USBs
Again, many thanks
Leave a comment:
Hi all set one of these zgemma boxes up at last
now for iptv got it going but keep having sound problems like film starts picture is fine but sound comes and goes can't work out why
anybody helpLeave a comment:
Just got a second one of these boxes however it now for some reason doesn't power on the display loads up to 100 then goes back to 50 and then back to 100 but never boots..... although the splash screen is showing...
Any ideas on how to fix thisLeave a comment:
Any one in Notts can help me put my sea lions into my Zgemma H1. I am a OAP and struggling
I have set the rest of the box up ok and all seems to be well. Been at it a week on and offLeave a comment:
Leave a comment:
