New 2015 Enigma2 Boxes DVB-C and DVB-S2 Zgemma Star H1 & 2S
  • loncell
    replied
    There's a 2 USB sockets , just press the front right side of the black plastic facia, it clicks open
    Leave a comment:
  • andy91
    replied
    Me personally I stuck on Openpli 4 as I'm used to these sort of images that ive used in the past on my Dreambox.
    Always best to mount a usb or hdd for epg as the internal memory will fill up.
    Andy.
    Leave a comment:
  • liam1982
    replied
    is it recommended to use a usb stick for the epg other than the internal flash for these boxes....cheers
    Leave a comment:
  • ellesmere11
    replied
    thanks for the links, but wanted to find someone using the image on this box and how it was, why would you choose a patched version of vix when openatv is just as good and supported by them.
    Leave a comment:
  • andy91
    replied
    These are some of the images if it helps.
    Andy
    Leave a comment:
  • andy91
    replied
    Box comes preinstalled with ATV image but cant answer your question. You could go to their website as the images are on there.
    Andy
    Leave a comment:
  • ellesmere11
    replied
    does the zgemma h1 work fine with openatv latest image running both cable and sat side by side. as openatv support the box.
    Leave a comment:
  • blueflash234
    replied
    Originally posted by andy91
    Its definitely the Openvix Apollo image which turns out the lights ive gone back to Openpli 4 to get Dreamplex working better.
    Lights on display are working fine on Openpli.
    Think the colour and look of the box will put a few off. Handset looks pretty decent but the back usb and Ethernet are far to close together and can see that being a problem long term.
    Andy.
    Andy i agree with digi a usb extension cable for a couple of quid much better and easier to use, its not just your box that's like that a vu solo se is the same its fiddly but the usb extension lead makes it much easier
    Leave a comment:
  • cactikid
    replied
    genuine vix do not support these boxes,so if you put a genuine image on box you know what that does!
    Leave a comment:
  • bugaloo41
    replied
    Sossy
    There are a few boxes on the market that are cheaper than the zgemma. They are not all E2 but cant see why this would suddenly send VM into a panic. Sure they are working to put a stop to it anyway.
    Andy
    Its defo the vix image that will fail to display channels. As lincsat says its the same on most if not all cloud boxes so may be the same issue given its modfied rather than supported officially. The image still works fine though and will function as intended but the display is just a green dot as you describe. Flash another image on it and it will be fine.
    Leave a comment:
  • sossybaby
    replied
    Originally posted by endemall
    Unlucky for you then mate. What you have here is an original box with legitimate support, I reckon Vix may even end up supporting the box. Enigma2 delivered to your door for ?80-?85...
    Or you can go to some uk sat sites and get their cheapest combo enigma2 box for ?137..... That's about 70% more cost, and for what? I'm so glad air digital are shaking up the market place. Had these running sweet for a while now with tsmedia, picons, epg all saved to flash and it's streaming films great!
    No cheap parts proper samsung tuners. Forget those crappy Q5's (?60) it's all about H1 with autobouqetsmaker, combo tuner for ?20 more and so many more features
    Is it only me who thinks this is a bad idea.
    it was those cheap f3 sat boxes flooding the market that forced sly to act in the first place. VM are now bound to do the same, spoiling it for everyone else.
    you say VIX intend to support these boxes.
    i'll ask RD.
    (oops sorry, he's banned).
    Leave a comment:
  • andy91
    replied
    Originally posted by cactikid
    what patched image is in system info?
    I tried two of the later patched Open Vix Apollo images.
    Andy
    Leave a comment:
  • cactikid
    replied
    Leave a comment:
  • andy91
    replied
    On the box I flashed with Vix there is nothing but a faint green light on display.
    With Openpli 4 it shows the time so definitely a bug with image and box.
    Andy.
    Leave a comment:
  • lincsat
    replied
    I have noticed with the I-Box2 and I-Box3 from this company that some boxes have front display working and others don't with the same image and bootloader. On those, they changed the spec as they went along. Maybe the same with these explaining why some are OK with patched ViX and others are not.
    Leave a comment:
